Old September 15th, 2016, 11:10   #31
DeliveryValve
That looks like a straight and clean car. Too bad it's dead.
- Richard-
2005 Passat TDI GLS Wagon 17x,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old September 15th, 2016, 11:12   #32
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
It was. Absolutely perfect. I dechained it at 62k miles a few years back. Other than that it was an all original untouched car. You can see by the looks of the engine even, that still looks new!
oilhammer
www.cardocautomotive.com
Old September 15th, 2016, 19:05   #33
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
This is literally my dream. It would make the perfect utility vehicle especially in the winter.
I was going to do the same thing but start with a V6/4motion wagon since the V6 trans is very close to TDI ratios. But then I started thinking about all the FE hits from the slushbox and 4 motion and desided it wasn't worth the work. On the flip side they are REALLY nice cars. Saw a nice 4 motion wagon at the junkyard a few weeks back that was almost in perfect condition. Seems the values of those cars really tanked.
I ended up getting a almost free wrecked MK5 5cyl that I fixed up and now I am trying to figure out how to swap an ALH into that.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old September 15th, 2016, 19:41   #34
Reddok
Reddok's Avatar
Fuel Economy: Jetta: 40.8 avg, 47.1 best. Jeep: 30 avg.
The internal gear ratios on the FAL are 29/41 41/35 and 41/37.
The internal gear ratios on the GMR are 29/34 34/29.
The first two sets of numbers are the front output group. So in the GMR it has a 29 tooth input gear, a 34 tooth idler gear and a 29 tooth output gear. This gives it a 1:1 drive to the 3.09 front differential. The FAL has a 1.2:1(35/29) drive to the 3.09 front differential giving it an overall final drive ratio of 3.73. The rear axle ratio of the FAL is probably 4.10 so multiplying it by 37/41 would give you close to a 3.73 final drive ratio as well.
So even though the gear ratios of the main gears are the same, the output gears are different and therefore the final drive ratio. This will cause an error code. As will the torque converter slippage. You can change the output gears as I have done, but the output housings vary depending on the diameter/number of teeth on the gear, so you may have to change the housings as well.
2000 Jetta 01M: Ventectomy, Snowscreen removed, Injection timing advanced, EGR dialed back.
2002 Jeep Liberty TDI Project: 2002 ALH, 1749VA, NSG-370 6-spd, PP764's on T4's, 11mm pump, PD150 intake, custom tune, Cummins lift pump, 2.8 CRD intercooler, 2.5" DP/exhaust with Magnaflow cat and Walker Quietflow muffler.
Reddok is offline   Reply With Quote
Old September 16th, 2016, 12:55   #35
oilhammer
oilhammer's Avatar
Thanks for the info, Reddok.
So if I am understanding correctly, there is a ratio for each of the gears (5 forward, 1 reverse), then the final drive ratio for the differential in the front of the case, but then this "third" change between the output shaft of the trans and the differential? I assume physically located at the rear portion of the unit?
Sorry for what sounds like a dumb question, just trying to understand. I've never torn into one of these units, never had to.
In other news, I tried plugging the TCM from the BHW car into my [other] AWM car, a FWD sedan. Car didn't like it, cluster went all lit up, like it was in limp mode, and I could not communicate with the TCM at all.
Plugged the original TCM back in, everything works normally. This may just be some incompatibility with the other modules, however... I would still think I should have been able to communicate with it, even if all it had to say was "I don't know where I am, what I am supposed to do, so I'll just sit here and do nothing".
But... I am assuming, possibly incorrectly, that both a 2004 AWM and 2004 BHW B5.5 would otherwise be using all the same communication protocols with all the modules. I cannot imagine why VAG would not use all the same stuff, so that the CCM, SRS, ABS, radio, etc. would all work the same regardless of what fuel goes in the tank.
oilhammer
Old September 16th, 2016, 19:22   #36
turbocharged798
You sure it was the connector was seated all the way? If it won't communicate then the TCU wasn't even booting up...
Old September 19th, 2016, 10:24   #37
compu_85
Gadget Guy
compu_85's Avatar
Ya, both 04 cars should use the same CAN bus version. I suppose it's possible they moved pins around on the computer but I highly doubt it.
-J
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
Past:
Old September 19th, 2016, 19:25   #38
Reddok
Reddok's Avatar
So there is the regular transmission gears 5 fwd, 1 reverse, then a reduction gear, then the final drive (ring and pinion) for the front diff. There is also a reduction gear for the rear differential as well.
Old September 20th, 2016, 04:53   #39
oilhammer
oilhammer's Avatar
OK, I understand now. Thank you. So the reduction gear ratio and the final drive ratio may not be the same front and rear as well, correct?
This is looking more and more like I will need to convert it to a manual. Was hoping to do a quick engine swap along with a couple modules and call it a day.
oilhammer
Old September 20th, 2016, 05:07   #40
oilhammer
oilhammer's Avatar
Here is the crashed car still on the trailer. I have to get some more pieces out of it.
Here's my Sport Utility Variant, patiently awaiting its TDI transplant (and probably leaving an oil stain under it from the leaky AWM ):
The Vanagon behind it would also like a TDI transplant, but it is already a diesel (and a manual ) so that might be a bit easier!
oilhammer
Old September 20th, 2016, 06:18   #41
compu_85
Gadget Guy
compu_85's Avatar
Perhaps you could find someone who can tune the trans computer.
-J
Present:
Past:
Old September 20th, 2016, 06:31   #42
oilhammer
oilhammer's Avatar
-J
I was thinking about that. In my [non expert] analysis, it would be a matter of overlaying the expected gear ratio values from the FAL TCM into the GMR TCM.
I am still scratching my head over the lack of communication I had when I put it in this other AWM car. KWP2000 is the communication protocol that VCDS shows for both of them.
oilhammer
Old September 20th, 2016, 07:03   #43
Reddok
Reddok's Avatar
Just swap the BHW trans in and run without the 4motion. You could always find the appropriate 4motion auto trans and TCU from Europe later.
You need to get the wiring diagrams for both TCUs and compare them. Any chance the BHW one was water damaged? They are known to have that happen sometimes.
Old September 20th, 2016, 07:05   #44
oilhammer
oilhammer's Avatar
No, no chance. It was a running driving car when it was crashed. Car was near perfect, never any water intrusion of any kind. I have taken care of it since it was new.
I will look over the diagrams at lunch today, if I have time. Busy day ahead of me. And the other Volkswagen guy left us, so I am all alone now.
oilhammer
Old September 20th, 2016, 11:01   #45
oilhammer
oilhammer's Avatar
Well it looks like dumbass Alldata doesn't have any wiring diagrams for the TCM and harness. And that's why we call it "Somedata".
They do have a pinout for the SST VAG1598/20 breakout box.
oilhammer
c5 a6 vs b5.5 4mo center shaft Machineman TDI Conversions 6 July 25th, 2016 04:55
Bhw swap into b5 a4 avant clenden3 TDI Conversions 0 May 4th, 2014 13:49
B5 BHW engine in Europe? got4g63 VW B5 Passat TDIs 6 March 26th, 2010 11:57
B5 > B5.5 Cluster Swap Done - Temp Guage not working ldavies83 VW B5 Passat TDIs 1 September 16th, 2007 19:44
B5 or B5.5 wagon with TDI/manual swap 86turbodsl TDI Conversions 2 December 22nd, 2006 08:44
Page generated in 0.17619 seconds with 11 queries
[Output: 141.78 Kb. compressed to 119.60 Kb. by saving 22.19 Kb. (15.65%)]
