Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old July 19th, 2016, 09:02   #46
tango_28
tango_28's Avatar
Our 2014 Ford Flex with DI does not have soot on the tail pipe, but my father in-laws Audi 2016 Q5 2.0 FSI has more soot than my 2003 JSW with big fat injectors.
03 TDI Jetta Wagon
06 LTD awd Freetstyle wagon
tango_28 is offline   Reply With Quote
Old July 19th, 2016, 11:35   #47
tomo366
TDI Lifer
tomo366's Avatar
My HHR SS was a heavy sooter......
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old July 19th, 2016, 13:44   #48
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I've never seen any Ecoboost that had "clean" tailpipes, ever. Even my dad's brand spankin' new F150 already is started to dirty its tailpipe, and it doesn't even have 5k miles on it yet. Heck, the 1994 F150 it replaces sitting right next to it has a cleaner tailpipe and it has covered nearly 300k miles (and it still has its original exhaust system, LOL).
oilhammer
www.cardocautomotive.com
Old July 19th, 2016, 14:26   #49
FordGuy100
FordGuy100's Avatar
We'll 1500 miles in and mine is still clean. I know GTDI's have a problem with it though.
04 Jetta BEW/5 speed TDtuning stage 1 Straight Pipe, 278k, 1985 F250 6.9IDIT. 05 2500 burb 4x4 ex govt.
FordGuy100 is offline   Reply With Quote
Old July 19th, 2016, 16:19   #50
Jeta Life
Fuel Economy: 42 mpg
Originally Posted by oilhammer View Post
Yep, that is a common thing on all direct injected gas engines. The GM 3.6L V6 CUVs' tailpipes are sootier than my PD TDI.
Don't worry, particle filters are coming for gassers soon enough, and then after that the EPA will have one more way to force everyone into EVs like it or not.
Particulate Filters are likely to be in Gasoline engines' future. Volkswagen's CR DPFs have not exactly gotten rave reviews here on the forum. Another emissions component to worry about for automakers and then consumers. The Big Three are hopefully working on some pretty big batteries that can tow 10,000 lbs and drive for 300-400 miles. They'll be coming up with a three row pick-up soon to match three row SUVs.
Jeta Life is offline   Reply With Quote
Old July 23rd, 2016, 04:32   #51
tdidieselbobny
tdidieselbobny's Avatar
My first tank yielded 416 miles(60 left) 35.4 pen and paper,32.9 on display. This was with A/C on about 95% of time. My first glance in the owners manual didn't say anything about the 1.4 for a timing belt,only the 2.0 and the hybrid motor engine,which I believe is the same. I found the sticker under hood for oil spec-just says 502.00,nothing about weight. I still don't think it's right waiting till 10k for first oil change.....
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 23k miles....'16 Kubota BX1870 MMM/FEL, 100hrs!And now an '03 Jetta TDI 5spd w/ 420k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old July 23rd, 2016, 05:27   #52
Congrats on the new ride, Bob. And you're right, the MKVI Jetta Sedan is actually almost exactly the same size as your B4. I've driven my daughter's with the four of us in it, very comfortable.
I am intrigued by the 1.4T, but I'd probably get laughed out of IDParts if I bought one. However, I've got my dealer looking for a '15 Jetta Sedan TDI for me. Sounds like they'll be able to sell them in October. May not cost any more than a '16 TSI after discounts. We'll see if it actually happens.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old July 23rd, 2016, 12:36   #53
tdidieselbobny
Is your daughters a 1.4T or a different motor? I'd say if it's not a 1.4,go take one for a test drive.
Old July 23rd, 2016, 13:24   #54
It was a 2.0. I'm not going to drive a 1.4T, because I won't buy another gasoline powered car. Afraid I might like it. I'll restore the B4 first.
Old July 23rd, 2016, 15:43   #55
Dimitri16V
Dimitri16V's Avatar
Don't try the 1.8 TSI , then
It pulls cleanly from 3rd gear at 1400 rpm all the way to 80 mph and gets 35mpg
And it has chains and a plastic oil pan ( replacing with a metal reinforced one )
We will still have to deal with the carboned valves though since VW took out the port injectors
10,000 mile oil changes , top oil filter mount and REAL independent rear suspension
I will miss the TDIs but I am not buying a diesel unless it is a 4 banger .
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old July 23rd, 2016, 15:48   #56
Dimitri16V
Dimitri16V's Avatar
502 or 504
Castrol 0W-40 , 0W-30, 5W-40
Mobil -1 0W-40
10K oil change is fine , my 1.8 TSI holds almost 6 qts
Old July 24th, 2016, 04:49   #57
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Wonder how they will hold up long term. Timing chain or belt?
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old July 24th, 2016, 05:26   #58
Dimitri16V
Dimitri16V's Avatar
1.8 has timing chain and balance shafts . Tensioners will need change , I am sure but it is pretty straightforward
I am happy they omitted the ValveLift system from the 1.8T . It looks it might be prone to mechanical wear in addition to the solenoids going bad
Thermostat is complicated , using electrically actuated valves to guide coolant flow around the engine
Water pump is on the tranny side of the engine
Oil spray underneath pistons is manipulated by the ECU , hefty oil cooler
Front mounted IC and plenty of potential with Turbo upgrades , this motor is a tuners dream
Front suspension similar to MKIV but with TT style bushings on the control arms
Old July 24th, 2016, 06:14   #59
FordGuy100
FordGuy100's Avatar
The 1.4 has been out in Europe for a while now. I believe VW went back to a belt on the 1.4. When reading about its features, it does seem complicated. Hopefully it lasts!
I've contacted a few tuning companies to see when tunes will be released. It looks like Revo has one ready to go, unitronic is working on one, and APR might be working on one. We'll see what happens.
Old July 24th, 2016, 08:25   #60
tdidieselbobny
Yeah,I'd like to know if it's belt or chain and what interval. The owners manual mentions all the engines except for the 1.4 by itself,it mentions the motor for the hybrid Jetta,but not sure if it's the same exact one without the hybrid. I bought an extended warranty till 125k,so any mods will have to wait a few years....
My week with a 2016 Jetta SE TSI Wankel7 General Automotive 3 November 13th, 2015 02:27
Traded in my 12 JSW tdi for a 16 GSW tsi totitan VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 September 29th, 2015 23:15
Jetta TDI to Passat TSI pleopard TDI 101 1 August 14th, 2014 09:57
2014 Jetta TDI or 1.8 TSI? sapgar VW MKVI-A6 Jetta Sedan (~ 2011+) 53 May 30th, 2014 05:51
2000 Jetta GLS TSI eAreEyeSee TDI Cars for Sale/Wanted 0 November 3rd, 2008 09:01
Page generated in 0.16320 seconds with 11 queries
[Output: 136.98 Kb. compressed to 114.96 Kb. by saving 22.01 Kb. (16.07%)]
