Old June 23rd, 2016, 06:00   #1
Ed ke6bnl
Ed ke6bnl's Avatar
Default My car locked the doors on its own.
we are use to leaving the keys in the car. we live away from other homes and put the keys in the arm rest. One morning my wife found the car locked and had to get AAA to open the car. the unlock button did not work for him and he had to pull the door handle from the inside. The door locked up again while my wife was getting ready to insert the key to start the engine. We now bring the key into the house. still do not lock the doors. Any Ideas. I will be getting a duplicate key with remote and mobilizer. thanks ED
1950 F1 street rod,1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock, no dump bed
1953 chevy 3100 AD, 4BT cummins motor, NV4500
1968 Baha Bug with 2.2 ecotec motor
1998.5 Dodge 2500 4x4 Cummins,2002 Vw Jetta
Ed ke6bnl is offline   Reply With Quote
Old June 23rd, 2016, 06:16   #2
UhOh
UhOh's Avatar
Search for "door lock control module" (how to repair or replace- your choice0
Old June 23rd, 2016, 06:18   #3
JETaah
Fuel Economy: 53 max, 42 min, average 46
It is caused by a faulty driver's door switch and the re-lock sequence that VW most brilliantly designed.
In a fully functioning system, if the car is locked, and you unlock it but do not open the door, the car thinks that you changed your mind and will re-lock the car after 30 seconds. It will use the door switch to determine that. And, since the door switch is broken, the car does not realize that the door was opened.
A good way to test this is to see if the overhead dome light turns on when you open the door....providing that the dome light switch is in the position to do that.
A way to cancel the re-lock sequence is to:
-- unlock the door, open it
-- put the key in the ignition and flip it to the ON position for a second.
That confirms that someone actually entered the car when it does not recognize that the door was opened. It will keep the car from re-locking until the car is locked from the outside again.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old June 23rd, 2016, 06:27   #4
Ed ke6bnl
Ed ke6bnl's Avatar
The door switch may defective since when we get out of the car the dome light does not come on with the drivers door like it does with the passenger door. I will look at this today. thanks for all the advice.
after writing this I discovered that I would be spending days just reading what is a common problem and literally hundreds of pages on the subject. at this point I may look at it and check for wires at hinge and maybe contact cleaner and maybe see about a part from a parted out Jetta or the Radio Shack fix. will see the route I will go.
Old June 23rd, 2016, 06:33   #5
steve6
search for 'stupid $3 door switch fix' thread.
steve6 is offline   Reply With Quote
Old June 23rd, 2016, 06:59   #6
sisyphus
sisyphus's Avatar
Our wagon did this once while my wife and kids were at the lake swimming and the key was INSIDE the car. Fortunately she was able to send the older kid into the car through the open sunroof.
sisyphus is offline   Reply With Quote
Old June 23rd, 2016, 08:10   #7
Vince Waldon
Vince Waldon's Avatar
2X... that one thread is the fastest way to get the info you need and figure out your options.
All three of my Jettas have malfunctioning driver door sensors, and the autolock snagged my keys once before I figured out what was happening. This past weekend I spent an afternoon tearing apart one of the doors and retrofitting the replacement Burgess switch as discussed in the thread. Got to have a Dremel with a very fine bit and some 2-56 hardware.
Now something that most other car owners take for granted...dome lights when you open the door...happens for me too. Luxury!!!
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old June 23rd, 2016, 08:21   #8
dweisel
dweisel's Avatar
Fuel Economy: 09 MB R320 Bluetec and too many ALH Beetles!
Try removing the battery from the FOB. You'll have to manually lock and unlock any doors,but this may help with the doors locking themselves.
LUBRICITY,LUBRICITY,LUBRICITY!
dweisel isn't diesel anymore!
dweisel is offline   Reply With Quote
Old June 23rd, 2016, 13:11   #9
hillelectric
Same thing happened to me twice, both times with a toddler in the car. First time took a lock smith, second time I had a valet key zip tied up underneath car. I did the "stupid $3 door switch fix" on drivers door and then later on passenger doors as they failed. Worked good and fixed problem but rather time consuming and takes some fine detail work on small parts. My drivers door has failed again after two years. Thinking of rigging a spring loaded push button switch on the drivers door and wiring into circuit so I don't have to deal with it anymore.
hillelectric is offline   Reply With Quote
Old June 23rd, 2016, 13:53   #10
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Yes, these guys are all over it.
In the meantime, always click unlock twice before locking and to leave it unlocked, open one of the doors that does work. What happens is, the door doesn't know it's been opened (or closed) and responds accordingly.
Old June 24th, 2016, 05:31   #11
Powder Hound
Powder Hound's Avatar
It is probably broken solder joints on the circuit board where the pins from the plug attach. If you decide to replace the latch assembly, please let me know (just PM me). I'll buy your old one.
Cheers,
PH
Old June 24th, 2016, 13:01   #12
Ed ke6bnl
Ed ke6bnl's Avatar
I assume the left and rt. door lock assembly are different BUT can the switch from the rt. side be used on the left, I have access to a rt side door. and the other 2 rear doors. thanks
Old June 24th, 2016, 13:15   #13
BobnOH
not-a-mechanic
Maybe you can tell, don't know which piece is the actual sensor
Front Door Lock Module Driver Side (A4)(B5.5)
Front Door Lock Module Passenger Side (A4)(B5.5)
Old June 24th, 2016, 15:54   #14
Vince Waldon
Although I've not pulled a passenger module apart it's definitively possible that the microswitch is NOT transferable... it's not a symmetrical part top to bottom or side to side IIRC.
The same replacement Burgess switch will fit either side, because it doesn't have the plastic rivets built into the case (hence the need to modify the existing holes somewhat) and so can be flipped over.
The other thing I'd say is that unless you have access to a brand new module for parts there's a good chance the switch in a used module is already well worn towards broken... if not already broken. I have never seen defective solder joints unfortunately.. always wear on the switch's plastic nub.
Battery flat/Doors locked patrickmorris VW MKIV-A4 TDIs (VE and PD) 5 May 11th, 2014 17:56
Battery drain only when doors locked BCKCX2 VW MKIV-A4 TDIs (VE and PD) 6 December 21st, 2012 17:33
Relay chatter when doors locked cada VW MKV-A5 Golf/Jettas 0 October 29th, 2012 10:40
Re: Horn No Longer Beeps When Doors Are Locked compu_85 VW MKIV-A4 TDIs (VE and PD) 0 October 5th, 2005 14:27
Re: Horn No Longer Beeps When Doors Are Locked spyglass VW MKIV-A4 TDIs (VE and PD) 6 October 5th, 2005 12:08
Page generated in 0.14766 seconds with 11 queries
[Output: 122.35 Kb. compressed to 101.83 Kb. by saving 20.52 Kb. (16.77%)]
