Old May 28th, 2016, 11:15   #1
bengone1
bengone1's Avatar
Fuel Economy: 40ish MPG
Default CR140 Runner Flap Delete plates
Runner flap deletes for CR140 engines. $140 shipped CONUS. 7 sets currently bagged and ready to ship. Please contact me at HRTechnikva@gmail.com (I don't get on TDIclub much)
https://goo.gl/photos/5gSWWbz7KZ7TmfeMA
Install instructions
http://www.myturbodiesel.com/wiki/in...0l-tdi-engine/
Discussion
http://forums.tdiclub.com/showthread...t=cr140+intake
Malone tuning services available- Contact Ben at HRTechnikVA@gmail.com
http://malonetuning.com
MK4, B5, B5.5 remote window control recoding available and VCDS MK5/6. SKC retrieval, Cluster matching, IMMO programming/delete.
bengone1 is offline   Reply With Quote
Old June 2nd, 2016, 07:58   #2
bengone1
bengone1's Avatar
First production sets are shipping tomorrow!
Old August 28th, 2016, 17:19   #3
GTSLOW
GTSLOW's Avatar
Anyone running these?
'15 Golf Sportwagen S M6
'04 Golf M5 - Koni STR.T's,H&R OE Sports, & Buzzken 2.5" Exhaust
'12 Jetta M6 - Sold back 6/29/17
'15 Passat SE M6 - Sold back 12/22/16
GTSLOW is offline   Reply With Quote
Old August 28th, 2016, 18:00   #4
bengone1
bengone1's Avatar
I think there are 6 sets installed. Big turbo, stock turbo, and even one stock DPF equipped car (not recommended). No issues to date.
Old September 7th, 2016, 13:37   #5
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
I have them installed on my wife's bone stock 2011.. No issues other than a flap position error which is an easy fix with either a tune or a small piece of aluminum from dieselgeek that's just for fixing that code..
Fuel economy is similar or maybe ever so slightly better, power feels about the same, maybe a pinch more around 1800-2200rpm.. Best part is we'll never have to wonder when the plastic butterflies are going to break off..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old December 30th, 2016, 17:02   #6
Strider17
TDI(s): MK4 and MK5
what happens with the motor? do you leave it in place? or is there a block off plate for the motor too
Strider17 is offline   Reply With Quote
Old December 30th, 2016, 17:09   #7
bengone1
bengone1's Avatar
I have removed the motor on all and even cut off the bracket on some of the tuned cars I have installed them in.
Old December 30th, 2016, 19:10   #8
Strider17
TDI(s): MK4 and MK5
how did you block it off?
Old December 30th, 2016, 21:30   #9
bengone1
bengone1's Avatar
I just keep the round insert the lever arm attached to. To be fancy I just grind off the nub for a flush appearance.
Old January 3rd, 2017, 07:36   #10
TDIJetta99
TDIJetta99's Avatar
I left hers in place.. still haven't made anything to eliminate the error though.
She has opted to keep the car and have it "fixed", so I'll be removing the plates when it goes in for the fix, and with the settlement $ it'll get "re-fixed" and tuned..
Old March 19th, 2017, 19:09   #11
bengone1
bengone1's Avatar
I will have a few sets out of the machine shop soon.
Old August 5th, 2017, 22:11   #12
Bobob729
TDI(s): Jetta
these are interesting how good are they working for everyone?
Bobob729 is offline   Reply With Quote
Old August 21st, 2017, 20:32   #13
bengone1
bengone1's Avatar
The machinist finally remembered how to make them.
Old August 22nd, 2017, 05:01   #14
dieselherb1
Matt I got a set of these from Ben. If I can every get mine sarted and running I could let you know. But Gene in Yorktown had them on his car before selling it back to VW. He said it was like night and day difference!
dieselherb1 is offline   Reply With Quote
Old August 29th, 2017, 16:18   #15
bengone1
bengone1's Avatar
One set sold and shipped, six left.
cr140 swap with stage 3 ecu immob delete shortysclimbin Private TDI Items for Sale/Wanted 15 July 31st, 2016 12:24
CR140 Exhaust flap used as compression brake? bloc VW MKV-A5 Golf/Jettas 13 March 27th, 2014 15:50
Intake Manifold Runner Flap dannomyte TDI 101 4 May 17th, 2012 06:53
Page generated in 0.16458 seconds with 11 queries
[Output: 126.99 Kb. compressed to 105.36 Kb. by saving 21.63 Kb. (17.03%)]
