Old March 15th, 2017, 22:18   #31
mrurbina
bump
Affiliated with the non-affiliated
mrurbina is offline   Reply With Quote
Old March 17th, 2017, 12:29   #32
shortysclimbin
shortysclimbin's Avatar
Are these with the TT shifter or the OEM diesel one? I ask as I need a TT shifter arm only
shortysclimbin is offline   Reply With Quote
Old March 17th, 2017, 18:25   #33
mrurbina
All 02Js are the same gas or diesel. I unfortunately don't have any TT shifter weights at the moment. (they are just a oem "shorter throw weight" ,that's the only difference)
Old April 3rd, 2017, 05:18   #34
paczo911
TDI(s): 1.9TDi
Hello All, newbie to the forum here, by the way it is a great place!
I would like to ask you about the 02A to 02J conversion, which many VW fanatics are doing.
I've got a project car - Mk3 GTi 16V 1996, ABF engine with the stock 02A CDA code gearbox.
If I remember correctly, installing the 02J into my car if I don't want to do any cutting, requires a VW Polo shift box and the internals of the VW Golf 4/Skoda Octavia/Seat Leon shift mechanism inside of it, right?
Probably there was a discussion of what I am about to ask next, but here goes - isn't it possible to just take the Polo's shift box along with its own internals and directly swap it in my Mk3 GTi? I am just wondering and I did not find any info on this...
Any input would be appreciated. Thank you.
paczo911 is offline   Reply With Quote
Old April 3rd, 2017, 21:02   #35
mrurbina
the polo itself quite short so i'm not sure if the cables are any shorter vs the mk4 cars. The only reason the polo box is used it's because it has the right shape(shaped like the 02a shifter box) and that box uses the correct relay lever in the box so you don't have to open the side a few mm. You'd have to buy it from mexico or europe on ebay.it's just cheaper to modify either the box or the shifter opening to make it work ..not much science in doing the swap. I had a 2013 shifter fitted in my mk3 so , anything is possible.
btw you don't need to cut ,you could use a grinder or cut off wheel to open it a few mm to get it open enough and drill either the box or the shifter opening to make it work.
Old April 16th, 2017, 09:05   #36
81dzlcaddy
PM'd you. In need of a kit this week.
81dzlcaddy is offline   Reply With Quote
Old April 25th, 2017, 14:30   #37
81dzlcaddy
Just bought a kit from Mr Urbina. He was great to work with and he had it to me before the weekend which was a great plus. Thank you for the fast turn around and having the smaller parts bagged was a great.
Old July 5th, 2017, 10:12   #38
mrurbina
back from the dead lol ..I'm now stocked with plenty of them after being out for a while !! first come, first serve!
Old August 1st, 2017, 10:28   #39
mrurbina
In stock bump!
Old August 14th, 2017, 11:58   #40
damac
TDI(s): none
i can't see pictures but got some questions for my project. im swapping a mtdi alh engine into mk2 golf.
i have diesel bare 02a trannys.
on the donor 2000 jetta diesel i unbolted the assembly from its tranny and kept all that hooked up to the shifter box/cables.
so does that simply just bolt onto the selector on my tranny? or was i supposed to pull some guts out of the jetta?
also wondering if i need any kind of brackets that bolt onto the tranny? right now for whatever reason my tranny is bare. when searching around i seem to see results for 02a bracket that holds shifter cables? and also another long looking bracket on the drivers side that goes from motor mount area to ears toward the front. not sure if its to support shifting and/or to hold a cable? i saw that in pictures of people swapping in cable clutch conversion and am not sure what it does.
damac is offline   Reply With Quote
Old August 15th, 2017, 21:36   #41
mrurbina
pm'd
Old October 21st, 2017, 08:38   #42
nickdvm
Pm,d.
nickdvm is offline   Reply With Quote
Old October 22nd, 2017, 14:37   #43
mrurbina
replied and BUMP
Mk4 1999.5 02A shifter swap to 2000+ 02J shifter kray VW MKIV-A4 TDIs (VE and PD) 16 September 21st, 2017 18:51
R&P Swap - 02A/02J arne487 Upgrades (non TDI Engine related) 6 January 30th, 2012 11:14
WTB: short shifter kit for 02a chiefdiesel Private TDI Items for Sale/Wanted 0 August 17th, 2011 11:09
FS DG Short Shifter Kit, 02A Transmission, Old Navy CCV kooyajerms Private TDI Items for Sale/Wanted 15 March 21st, 2011 10:37
Page generated in 0.14089 seconds with 11 queries
[Output: 109.70 Kb. compressed to 91.55 Kb. by saving 18.15 Kb. (16.55%)]
