Old July 23rd, 2015, 15:06   #16
Daemon
While attempting to install a Dieselgeek short shifter -> http://www.dieselgeek.com/5_Speed_VW.../ss-sigma5.htm I managed to shear off the bracket that holds the up/down lever.
I'm not clear on what all the parts are called, but I guess I need a new shift tower? It's the part that bolts to the transmission and contains the splined shaft which rotates and moves up and down. I do not need the golf club shaped lever, nor the up/down lever. I do need the plastic bushings that go around the pin for the up/down lever though, because Dieselgeek's instructions say to reuse them, and mine are stuck and falling apart.
Help?
Daemon is offline   Reply With Quote
Old July 27th, 2015, 19:37   #17
Daemon
Mr. Urbina answered all my questions and shipped the parts I needed the next day.
Excellent seller!
Old July 28th, 2015, 03:39   #18
mrurbina
Excellent seller!
Thanks boss, good buyer too.
Affiliated with the non-affiliated
mrurbina is offline   Reply With Quote
Old January 12th, 2016, 07:16   #19
mrurbina
Have more in stock .....BUMP
Old January 12th, 2016, 12:03   #20
Digital Corpus
Digital Corpus's Avatar
I've been seeing that some club members are using the Polo's shift box. How does it differ from this one?
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | DC Stg IV Clutch w/ 14 lb flywheel | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old January 12th, 2016, 14:55   #21
Soupinmycoupe
Soupinmycoupe's Avatar
Fuel Economy: 46-51mpgs
on a scale of 1-10 (oil change being a 2) how hard is it to swap this linkage?
Soupinmycoupe is offline   Reply With Quote
Old January 12th, 2016, 15:37   #22
ottomatic
I was planning on my Diesel Geek Short Shift kit this weekend ....tips??
15 GSW SE TDI 6M Reflex Silver
ottomatic is offline   Reply With Quote
Old January 13th, 2016, 14:49   #23
mrurbina
The polo shift box is more for mk3 cars like b3/b4 passat/corrado/golf/jetta because it makes up for the space that the mk4 box would have ..since it's not as tall as mk3 boxes but it's not really a big deal. Not to mention the cost since polo boxes are imported. So, not a big deal if you don't care about some gap
.maybe a 4 . All you would do is drop your shifter box, remove the bolts from the trans (7 total) and just splice the reverse switch in. As stated above,you'd just have to come up with a way to cover the gap between the top of the box and the exhaust tunnel..it's not bad.
Check out this video and DG's play list
https://youtu.be/wZFx5RjnHSQ
Old January 16th, 2016, 15:51   #24
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Into another Mk4? Cake.
Some additional steps required for older stuff.
You beat me to changing your location to "Hella NORCAL"
Great minds think alike
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old January 16th, 2016, 15:57   #25
Matt-98AHU
Matt-98AHU's Avatar
Polo box is a better OE fit. But if you don't want to pay to import one and swap in the components from a mk4 box, the mk4 box is just fine. Needs some modification, as does the chassis of your car, to fit. But all in all, not bad.
There will be a gap to the body, but I generally fill it with some carpet padding. Makes the car quieter than ever
Old April 2nd, 2016, 18:00   #26
mrurbina
Ready to ship, Bump
Old June 17th, 2016, 11:33   #27
Jay-Zee
Fuel Economy: 1998 Jetta TDI -50mpg
Any of these kits available and if so would it work on my 1998 jetta tdi.
Jay-Zee is offline   Reply With Quote
Old July 17th, 2016, 04:23   #28
mrurbina
Bump
Old September 26th, 2016, 05:52   #29
mrurbina
Bump😀
Old February 11th, 2017, 21:15   #30
mrurbina
Bump
Mk4 1999.5 02A shifter swap to 2000+ 02J shifter kray VW MKIV-A4 TDIs (VE and PD) 16 September 21st, 2017 17:51
R&P Swap - 02A/02J arne487 Upgrades (non TDI Engine related) 6 January 30th, 2012 10:14
WTB: short shifter kit for 02a chiefdiesel Private TDI Items for Sale/Wanted 0 August 17th, 2011 10:09
FS DG Short Shifter Kit, 02A Transmission, Old Navy CCV kooyajerms Private TDI Items for Sale/Wanted 15 March 21st, 2011 09:37
Page generated in 0.17079 seconds with 11 queries
[Output: 128.42 Kb. compressed to 106.90 Kb. by saving 21.52 Kb. (16.76%)]
