Old November 22nd, 2014, 20:49   #1
mrurbina
Default 02J shifter swap kit for 02A/early 02J transmissions
Well, I'm a vendor now. So I'm selling all the parts needed for swapping your old 02A style shifter mechanism to the newer 02J one. This fits any 02a and earlier mk4 (pre-2000)
Kit includes:
Shifter assembly
cables and bracket
shifter tower and coupler
reverse light with pigtail to splice to your harness.
price is $130 + s&h
(things are sold as is ,when taken off)
If you only need certain parts ,not the whole setup..I can provide those too as long as I have them.
pictures:
this is the ball type but I also sometimes carry the clip style
mrurbina is online now   Reply With Quote
Old November 22nd, 2014, 21:19   #2
aslspiderman
aslspiderman's Avatar
TDI(s): 98 Jetta
Fuel Economy: Really good!
Your picture links don't work
98 Jetta, K03/04, 520 sprints, aligator chip, SRS, torsion bar, Billy HD's, TT bushings VR6 clutch, GLX seats
aslspiderman is offline   Reply With Quote
Old December 5th, 2014, 16:51   #3
turborado
TDI(s): none
Default 02J shifter swap for 02A
I just purchased the conversion kit from mrurbina and is complete with good parts. Fast shipping and no hassles. Two thumbs up!!
turborado is offline   Reply With Quote
Old March 1st, 2015, 19:24   #4
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
Would this kit work on a 1997 Passat? Would any modifying need to be done to retain the original shift knob?
If it'll work have any available?
'97 Passat: 315,XXX Miles, Malone Eco Tune, Bosio PP 502, FAT/KFC Mod, Ventectomy, DRL Kill, 1000 Mile Club x3 / Auto Trim DESIGN
97B4TDi is offline   Reply With Quote
Old March 2nd, 2015, 18:48   #5
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
I never received a pm
Old March 4th, 2015, 00:59   #6
Soupinmycoupe
Soupinmycoupe's Avatar
Fuel Economy: 46-51mpgs
Do you by chance have a pic of the "clip" style clip?
Soupinmycoupe is offline   Reply With Quote
Old March 4th, 2015, 04:25   #7
mrurbina
here's a picture of what clip ends look like.
some people prefer those over the ball/socket type ..but they're pretty much the same.
Affiliated with the non-affiliated
Old March 4th, 2015, 09:38   #8
Abacus
That helpful B4 guy
Abacus's Avatar
Yes, it'll work, Windex swapped one in the B4V I bought. He cut a little off the top of the shifter and tapped it so the OEM shifter screws right on. I can get pictures if you want.
He also added the short shifter and it shifts smoother and better than any car I have driven yet. I'll be doing the same thing to my sedan when spring arrives.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old March 4th, 2015, 18:39   #9
mrurbina
Abacus, thanks for the input! ....bump..
Old March 6th, 2015, 06:20   #10
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Here is what Abacus' 02J install looks like (in car):
There was a little clearancing needed to have the shifter box sit flush to the tunnel - a notch at the base, and about 3/16" at the top left to clear the linkage on the shifter.
Alternatively, you can use threaded rod and spacers to space the box down (would require some sort of insulation to keep out road/wind noise/air intrusion). This way will allow you to omit cutting down and threading the shifter, but your shift throw will be a little longer. I tried both and settled on the above.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 6th, 2015, 19:10   #11
T-Roy
Definitely doing this to my B4V, it is the worst shifting VW I own...I like very smooth, notchy shifts and it is pretty awful.
My favorite shifter is my MK2 ECO with full USRT kit and all UHMW bushings, it is amazing.
T-Roy is offline   Reply With Quote
Old April 1st, 2015, 23:05   #12
Digital Corpus
Digital Corpus's Avatar
I need to figure out what is going on with my insurance before I move down this route, but I'm staying subscribed cause I want one
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | DC Stg IV Clutch w/ 14 lb flywheel | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old April 1st, 2015, 23:58   #13
vanbcguy
vanbcguy's Avatar
I've got this setup in Jezebel. Most awesome shifting car I've owned. Add a Polo shift box for your B4 and Synchromesh fluid and you get the perfect OEM+ experience. All factory parts and 100x better than the stock 02A stuff.
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old July 18th, 2015, 11:21   #14
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
How much for shift tower, tower base & housing only?
runonbeer is offline   Reply With Quote
Old July 18th, 2015, 20:02   #15
mrurbina
Pm sent
Mk4 1999.5 02A shifter swap to 2000+ 02J shifter kray VW MKIV-A4 TDIs (VE and PD) 16 September 21st, 2017 17:51
R&P Swap - 02A/02J arne487 Upgrades (non TDI Engine related) 6 January 30th, 2012 10:14
WTB: short shifter kit for 02a chiefdiesel Private TDI Items for Sale/Wanted 0 August 17th, 2011 10:09
FS DG Short Shifter Kit, 02A Transmission, Old Navy CCV kooyajerms Private TDI Items for Sale/Wanted 15 March 21st, 2011 09:37
Page generated in 0.17679 seconds with 11 queries
[Output: 130.12 Kb. compressed to 108.31 Kb. by saving 21.81 Kb. (16.76%)]
