Old August 30th, 2017, 05:55   #61
dowster
Doing the old 2yr thread bumparoo. Curious as to how this swap has been treating you. I recently bought a 1986 BMW that has been running nicely so far but may need to become a bit less 'gassy' down the road so I'm looking at other engines that could make their way into the car. How was your experience with getting the diesel ECU to play nicely? You mentioned that you had it tuned with the immo delete and dpf / emissions delete. Have you had any struggle sourcing parts for the engine since the whole 'dieselgate' went down?
dowster is offline   Reply With Quote
Old September 3rd, 2017, 06:50   #62
nate0031
nate0031's Avatar
TDI(s): 96 B4 Passat
It's been doing well. I've got no complaints. It has well over 30,000 since the swap. It's towed the tandem jet ski trailer 1,000 miles round trip to TDI Fest, the 17 ft utility trailer 1,100 miles to Texas, and the 26ft travel trailer 300 miles across Ohio.
I haven't had any issues with parts either, although I can't say I've needed to replace any. It's possible you could have a harder time sourcing parts for a swap, but I couldn't comment there.
2005.5 VW Jetta - 1.9 Turbo Diesel - 5 Speed
2000 Audi A6 - CJAA Common Rail TDI - Quattro - 01E
2005 Ford F-350 - 6.0L Turbo Diesel - Auto - 4x4
nate0031 is offline   Reply With Quote
Old September 3rd, 2017, 07:28   #63
dieselherb1
Nate, sent you a PM
dieselherb1 is offline   Reply With Quote
Audi A6 Diesel, A6 and A8 Hybrids Models to Get Delayed U.S. Launch TDIMeister Other VW Group TD(I)s 7 December 10th, 2011 21:18
2.0 Common rail a6 Injector coding c_higgins OBD Scanners 3 November 29th, 2010 16:58
Audi Cross Coupe Quattro Concept: 2.0 Common Rail TDI Is Here (204hp/295 lb-ft) chewy TDI News/Tech 35 April 29th, 2007 20:56
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
Audi A8 3.0 TDI 24valve common rail 2fastdre TDI News/Tech 13 September 8th, 2003 08:53
Page generated in 0.12208 seconds with 11 queries
[Output: 59.61 Kb. compressed to 54.31 Kb. by saving 5.30 Kb. (8.90%)]
