Old April 16th, 2015, 05:09   #46
nate0031
nate0031's Avatar
TDI(s): 96 B4 Passat
Thank you guys! mtushmoo, I'll pull up my fuel tank pictures and respond in your thread. Sent you a PM Rafedial.
2005.5 VW Jetta - 1.9 Turbo Diesel - 5 Speed
2000 Audi A6 - CJAA Common Rail TDI - Quattro - 01E
2005 Ford F-350 - 6.0L Turbo Diesel - Auto - 4x4
nate0031 is offline   Reply With Quote
Old April 17th, 2015, 17:01   #47
vw_nut
Your build gave me the inspiration to think about a common rail swap in the mk2, I've enjoyed your build nice work
My 1Z Rabbit Truck Conversion http://forums.tdiclub.com/showthread.php?t=281944(2013 Tdi Fest Radical Class Winner)
bv43a, pd150 intake, r520's, 11mm pump, BHW pistons, integrated rods, stg 5 Malone tune, port n polish head (whitebread), stg 2 cam, SB stg 2 clutch,
vw_nut is offline   Reply With Quote
Old April 24th, 2015, 07:15   #48
nate0031
nate0031's Avatar
Been a busy few weeks, haven't had time to post much. Apparently there were two different accumulator styles for that car, and I got the wrong one. Just received the correct one, so we'll see if AC works this weekend.
I have just under 800 miles on it now and I have run it to about a half tank twice then filled. I was way to curious about mileage to let a full tank go through, lol. The first time, with my erratic test driving and about 70/30 highway/city, fetched 38 MPG. The second time with easier driving, no full throttle testing but on the same 70/30 commute to work, got 40.3. I'm pretty happy, and that's on snow tires too. The highway is cruising at (about, no cruise yet) 65 MPH at ~2500 RPM. I'm really hoping to get even more into the low 40's when I get new tires next month, something more touring oriented with a harder compound and 10mm narrower. We'll see though. Between that and a swap to a euro trans, I think it'll do pretty well for itself.
Old May 6th, 2015, 12:17   #49
nate0031
nate0031's Avatar
Nice weather last weekend, so we took the car for a nice drive. Snapped a couple pictures:
Old June 8th, 2015, 06:30   #50
nate0031
nate0031's Avatar
Got the AC working. Looked at the AC controller and the compressor shutdown code indicated that the ECU was not giving it permission to engage, likely because of the smorgasbord of errors.
There are three wires going from the ECU to the AC control head. The schematics aren't in front of me, so double check these. One, located on T10p if memory serves, is the tach signal. The other two, T17k/2 and T17k/3, are for the control head asking permission from the ECU to engage the compressor. It wouldn't do it without a tach signal, but with the tach, when the AC was commanded on by the controls in the cab, the control head would send 12 volts to the ECU on the black/yellow wire (T17k/2). Meanwhile, the black/gray wire (T17k/3) would stay at 0. I had a hunch that wire was supposed to go high (to ~12 volts) to let the control head know it was allowed to engage the compressor. I connected those wires directly to each other and sure enough, the compressor shutdown code changed and the compressor kicked on. So I disconnected them from the ECU and soldered them directly to each other. Now when the control head sends 12 volts to request to engage the compressor, it sees it's own signal and thinks the ECU is giving it the go ahead.
I charged it like normal and now it's nice and cold. Now to fix the cruise.
Old June 8th, 2015, 08:49   #51
TDIsyncro
TDIsyncro's Avatar
TDI(s): Audi/TDI x 2
Fuel Economy: 50-60mpg HWY, depending on speed and wind
nice diagnostics going on there. Its great to find simple solutions like that. The euro TDI 01E will make a very nice upgrade and go along way to your mpg goals.
2001 Audi A4 - New Project - 2.0TDI CR 450HP All Turbo
http://forums.tdiclub.com/showthread.php?t=270527
2007 Canyon w/2011 TDI CJAA CR
http://forums.tdiclub.com/showthread.php?t=415533
TDIsyncro is offline   Reply With Quote
Old June 8th, 2015, 08:59   #52
nate0031
nate0031's Avatar
Thanks! Yea, I can't wait to do the tranny swap. This one isn't bad, but I know it'll be way better with proper ratios.
Old September 10th, 2015, 10:24   #53
iwannajettatdi
iwannajettatdi's Avatar
Fuel Economy: 43/49/46
Nate,
I have a few questions for you. PM'd you. Sweet swap! How are things rolling along now? Any more long term MPG reports?
2002 Eurovan TDI BHW 02d syncro project - The Adventure Bus
2011 MK6 Golf, 120k miles - Soon to be sold
Gone-2006 V10 Touareg TDI
DEAD-99.5 A4 Jetta, 349,919 miles RIPieces
iwannajettatdi is offline   Reply With Quote
Old September 10th, 2015, 13:43   #54
mr_y82
One does not...
simply make a controller to intercept the TPS signal from the accelerator pedal, and use a PID controller to modify it for the cruise control.
...You guys never cease to amaze me, lol
Great swap!
I got a pair of crimpers from Lowe's for $10, chopped the tip/wire cutter section off, then used the crimping section to bead the tube. One crimp at a time. All the way around. My hands are sore, lol.
I bet...
Malone Stage 2 Econo-Tune!;BuzzKen downpipe w/ cat!
2MicronTech Contain Flow and Pure flow Adapter FROSTHEATER
Appalachian Diesel Works, NC!(TRUSTED TDI MECHANICS)
Pre-tune: ~10k-70k mi = 40.5 mpgs; mpgs since tune_f_u_e_l_l_y_ ^
mr_y82 is offline   Reply With Quote
Old October 19th, 2015, 11:02   #55
nate0031
nate0031's Avatar
Responded to your PM. Thanks everyone. Been great so far. Right now I'm getting 37-38 when mostly city/short trips. 41 on the highway going 70-75. Got 17 towing the 26ft camper at 60 weighing 4200lbs, 28 when towing the 17ft flat utility trailer, ~1500 lbs. And 32 pulling the jet ski, ~600 lbs.
I've put just over 10k on her so far. No issues yet. Looking to upgrade the clutch soon and hopefully get a euro TDI box in there.
Old October 20th, 2015, 05:19   #56
mcneil
Great swap!
Did you ever get cruise working with the VSS over CAN? If so, what's the CAN ID for speed and how is it formatted?
2000 Jeep TJ TDI with a 4L65e Automatic
http://forums.tdiclub.com/showthread.php?t=349116
slowly coming together
mcneil is offline   Reply With Quote
Old October 20th, 2015, 05:46   #57
TDIsyncro
TDIsyncro's Avatar
Glad it is running great for you. The fuel mileage sure dips down when pulling. I was surprised to see it go down that much for flat trailer, but I guess a 17ft is pretty big. Nice job pulling the 26ft camper behind A6 TDI!
Old October 20th, 2015, 05:47   #58
TDIsyncro
TDIsyncro's Avatar
Originally Posted by mcneil View Post
Great swap!
What he says.
I was looking around for more CANBUS ID's. Only have a couple right now.
Old October 20th, 2015, 05:52   #59
nate0031
nate0031's Avatar
Great swap!
I haven't yet. Just got my replacement Raspberry Pi to keep working on it. I am rigging up a simple Arduino solution at the moment that'll use a PID controller to alter the accelerator signals to the ECU. That'll get me cruise in the meantime, I'm really missing it, lol. When I get a chance I'm going to log the CAN traffic on a friend's 2010 TDI and figure out the needed ID's and format. I'll need to figure out the ID's from the steering wheel module as well, as the cruise commands from the stalk are sent to the ECU via CAN.
Old October 20th, 2015, 06:03   #60
nate0031
nate0031's Avatar
Yea, it sure dips down with the camper, lol. Still about 65% better than with the excursion and 7.3. I feel like the Excursion should be getting better than it is (about 11), but even going slow didn't seem to have a significant impact. Might just be how it is with the heavy aerodynamic load that comes with the camper.
I was expecting a few better with the utility trailer too, wondering if the aero load from the taller furniture or the extra axle is what pulled it down.
What he says.
I'll be sure to post them up when I get them. Which ones do you have so far?
Audi A6 Diesel, A6 and A8 Hybrids Models to Get Delayed U.S. Launch TDIMeister Other VW Group TD(I)s 7 December 10th, 2011 21:18
2.0 Common rail a6 Injector coding c_higgins OBD Scanners 3 November 29th, 2010 16:58
Audi Cross Coupe Quattro Concept: 2.0 Common Rail TDI Is Here (204hp/295 lb-ft) chewy TDI News/Tech 35 April 29th, 2007 20:56
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
Audi A8 3.0 TDI 24valve common rail 2fastdre TDI News/Tech 13 September 8th, 2003 08:53
Page generated in 0.15740 seconds with 11 queries
[Output: 140.88 Kb. compressed to 118.57 Kb. by saving 22.31 Kb. (15.84%)]
