Old April 16th, 2016, 17:35   #256
b5converison
b5converison's Avatar
Fuel Economy: never measured :)
Originally Posted by X-Man View Post
Top quality tubular manifold for 8V 1.9TDI transverse engines. To fit GTB1756vk, GTB2056vk and GTB2260vk and hybrids based on the above turbos.
This manifold comes with lifetime warranty against cracks.
- turbo flange and collector made from billet steel 316L
- only seamless elbows are used
- turbo will sit exactly in stock position so stock downpipe and intake pipe can be used (with proper flange and adapter) as well as stock oil return
- EGT probe port already in the collector
- the manifold is welded by highly qualified fabricator with a lot of experience in welding manifolds and fitting GTB turbos
It's going to fit the following vehicles:
Volkswagen Golf mk4 / 5
Volkswagen Jetta
Volkswagen Bora
Volkswagen Polo 9N / 9N2 / 9N3
Audi A3 8L / 8P
Seat Ibiza Mk3 / Mk4
Seat Cordoba
Seat Leon 1M / 1P
Seat Toledo
Skoda Octavia Mk1 / Mk2
Skoda Fabia Mk1
And many more...
600 delivered within the UK
650 delivered to the US and Canada
Top quality short manifold for 8V 1.9TDI transverse engines. To fit GTB1756vk, GTB2056vk and GTB2260vk and hybrids based on the above turbos much cheaper alternative to tubular manifolds with the advantage of much quicker spool.
Ideal for budget - daily driving applications where quick spool is the priority.
Lifetime warranty against cracking.
It holds turbo very close to stock position.
200 delivered within the UK.
240 delivered to the US or Canada.
lifetime warranty on the tubular ??? well that is a new one to me ))
My darkside manifold from a b8 audi ( fitted to my b7 2.0 BRD) has cracked in 200 miles ... but it cracked near the head flange on 3 runners and I had a big raw with Ryan at the time as I remember on how is this possible ...
So it did not crack on the collector side whilst there is the highest melting point and it cracked on the welds to the flange ..
Firs main problem was I believe the vibration and the whole setup whilst my vklr is not a vk and it was falling quite away from the head when installed .
Second main problem was that I knew this was coming and I have asked Ryan for advice and possibility of supporting the turbo as it`s heavy and is got a tendency to pull outside due to it`s own weight .. I`ve been told that if I do any kind of support on the turbo I will void the warranty .. well after 200 miles I shipped it back to them and I told them to weld it properly (in/out) as you could also see that the only runner that did not crack had a thicker weld on the inside ..
When I got it back I have fabricated a support system with rose end joints to hold the turbo strapped to the head in but allow movement same time whilst these manifolds will obviously expand under high heat and never had a problem since knock wood !
not a pleasant experience to take the turbo off and send the manifold away to have it done properly after you paid some nice money and you don`t get what you have paid for !
just curious on your terms and conditions .. if you have anything like that ..
also how difficult would be for your technical guy that did the cad dwgs on this manifold to do a 4-2-1 manifold for a longitudinal engine .. (even transverse ones) I would say these would improve flow and spool a lot more ..
sorry for long off topic story
b5converison is offline   Reply With Quote
Old April 16th, 2016, 17:42   #257
b5converison
you adjust it all on the car and observe the results with vagcom:
http://uk-mkivs.net/topic/34834-vnt-...oost-problems/
+1
I think that is the best explanation on how to setup/convert a electronic to a vacuum actuator and also get it right from the first without ever touching it again!
Old May 18th, 2016, 14:04   #258
smelly621
Hey x-man, I'm looking for a bv43a or something similar to bolt up to a bhw exhaust manufold for a tdi swap project. Could you let me know if you have anything suitable?
Thanks!
smelly621 is offline   Reply With Quote
Old May 18th, 2016, 14:07   #259
X-Man
X-Man's Avatar
Thanks!
any chance you could message us on facebook? would be easier to chat there
TDI turbochargers for less
turbos@xman750.co.uk - GTB1756vk, GTB2260vk, 1.9TDI hybrids and more...
www.facebook.com/XMan-Turbos
X-Man is offline   Reply With Quote
Old May 18th, 2016, 23:59   #260
smelly621
I don't have a Facebook account - but sending a pm with email info.
Thanks!
Old June 26th, 2016, 12:19   #261
peppe_tdi
TDI(s): PD105
Volkswagen Jetta
Volkswagen Bora
Audi A3 8L / 8P
Seat Cordoba
Seat Leon 1M / 1P
Seat Toledo
Skoda Fabia Mk1
And many more...
how much close to stock position mate?
peppe_tdi is offline   Reply With Quote
Old June 26th, 2016, 13:40   #262
X-Man
X-Man's Avatar
just please PM me mate or message us on facebook
cheers
Old January 30th, 2017, 08:41   #263
fungi131
TDI(s): 2005 golf
I recently purchased a 17/56 hybrid from X-Man.
https://m.facebook.com/story.php?sto...61&__tn__=%2As
I am very happy with my purchase. Excellent communication, prices, and prompt shipping.
I would not hesitate to do business here again.
-Thanks.
fungi131 is offline   Reply With Quote
Old August 17th, 2017, 14:15   #264
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
need log ex manifold for GTB1756vk with ex gasket to manifold to turbo and ex flange and gasket shipped to me how muck and how long
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old August 17th, 2017, 15:57   #265
X-Man
X-Man's Avatar
replied to your comment on facebook just please drop us a message and we will sort it out
Why is that people think that hybrids are alternative fuel? I hate hybrids!! BioNerd General VW Discussion 29 January 6th, 2012 19:43
honeywell says turbos beat hybrids Jack_Berry General Automotive 1 January 4th, 2011 14:47
2260vk for sale CERBER Private TDI Items for Sale/Wanted 4 April 4th, 2010 08:25
For Sale: Brand new Old Man Intake (OMI) TheHolyCobra Private TDI Items for Sale/Wanted 5 September 27th, 2009 22:28
Turbos For Sale!! Scott_DeWitt Private TDI Items for Sale/Wanted 12 April 11th, 2007 12:41
Page generated in 0.14443 seconds with 11 queries
[Output: 107.73 Kb. compressed to 92.97 Kb. by saving 14.77 Kb. (13.71%)]
