Old June 22nd, 2013, 16:43   #1
Jesse_Boyer
Default '05.5 BRM. low-beam on one side won't work. low voltage
I did a little searching and can't quite figure this out yet. We're getting ~12v to both high beams as well as the drivers low beam, but virtually nothing on the passengers low beam. Trace voltage only.
The high-beams intermittently shut off once/twice as well... not sure why.
New bulb obviously didn't do anything; any thoughts on the low voltage? bad ground? Some kind of controller causing trouble?
'03 Nemo Blue S6, AirLift, Garage queen/spare.
'02 Black S6, 01e swap, muffler delete, permanent smile maker.
'00 A6 2.7t 6sp. Message me for parts requests
'01 allroad 6sp, parts car. Message me for parts requests
Jesse_Boyer is offline   Reply With Quote
Old June 22nd, 2013, 19:52   #2
Jesse_Boyer
case closed (for now.) In a final effort, I sprayed a little Deoxit on the contacts of the headlight plug and the headlight. Amazingly, this appears to have worked. All lights functional (other than the addition of the yellow driving lights in the GTI bumper,) work perfectly. These appear to be an add-on and the wiring is substandard... and I don't even know how to turn them on.
The dash light for a failed light is still 'on.' The system states "Right side marker defective" but I don't see any lights that aren't functional. Definitely looking for a solution to this ASAP.
Old June 23rd, 2013, 07:50   #3
Jesse_Boyer
update: the marker light apparently works intermittently. I KNOW it was functional yesterday, but the right side bumper/marker light doesn't work this morning. I'm going to try a new bulb, but I highly doubt the bulb is the culprit.
Drivers side Headlight low beam only and Taillight issue BuzzWagon VW MKIII-A3/B4 TDIs 4 September 8th, 2011 10:25
Intermitent low beam X1 ---> No low X2 thatvwguy TDI 101 2 August 18th, 2008 04:10
Quad Beam TDI --- Low Beam & High Beam Together mandrake slink Upgrades (non TDI Engine related) 7 June 11th, 2007 10:24
Drivers side headlight is very dim on low beam and goes out when on high beam alblackbug53 Upgrades (non TDI Engine related) 4 March 24th, 2007 17:21
Dead Low Beam on the Driver Side grelli VW MKIV-A4 TDIs (VE and PD) 13 March 22nd, 2007 02:19
Page generated in 0.13122 seconds with 11 queries
[Output: 58.50 Kb. compressed to 52.95 Kb. by saving 5.54 Kb. (9.48%)]
