Old February 16th, 2013, 06:30   #31
schultp
schultp's Avatar
Andrew has been working on a new bracket and filter set up. See the thread in the MK6 JSW subforum with some pics of the prototype. He definitely took the concerns about needing further filtration and came up with a great update from the looks of things. Stay tuned!
Paul.
2010 JSW TDI, 6sp manual
schultp is offline   Reply With Quote
Old February 16th, 2013, 09:57   #32
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Originally Posted by bhutchins View Post
a lude analogy, but a condom is 99%, not 100% but close. not using one is looking for trouble. you want one that's 100%???
5uM filter is not 100%, but 99%, go without and you could be looking for trouble. I know, I've got a tween and a teen. lots of touble, but worth it.
Just trying to be clear here, but are you saying a 5-8 micron filter traps 99% of the stuff that the stock filter doesn't? The filter is 8uM absolute, 5uM nominal.. Not sure what the stock one is..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is online now   Reply With Quote
Old February 16th, 2013, 17:24   #33
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
The filter has the same filtering porosity as the filter already under your hood. if you want finer filtering it's going to be much larger and cost more (over-engineered). This is a simple and effective method of adding protection.
The install only took me about 10 minutes.
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old February 16th, 2013, 18:32   #34
TDIJetta99
TDIJetta99's Avatar
but if it's no better than the stock filter in the filtration department, it's really only protecting the tank and sending unit from being contaminated. far from 99%...
Old February 17th, 2013, 00:56   #35
elkriver
Aren't there a couple of electric pumps being protected also?
elkriver is offline   Reply With Quote
Old February 17th, 2013, 06:27   #36
TDIJetta99
TDIJetta99's Avatar
There's one electric pump in the sending unit, and another under the hood.. The one under the hood I believe is after the factory filter..
Old February 17th, 2013, 07:04   #37
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
which is odd, considering the amount of carbon brush material and copper particles they shed over time...
DPM is offline   Reply With Quote
Old March 2nd, 2013, 15:56   #38
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Just did my second fuel filter change today @ 44262 miles. Absolutely clean. I've been using B2-B5 biodiesel and 2-4 oz of Optilube XPD as a HPFP preventative measure. I did siphon out the canister and wiped it dry. Primed the system as I added 2Micron auxilliary return filter after changing the OEM fuel filter. Hope the 2micron filter never has to replaced for a HPFP replacemnet! Link to prime the fuel system system http://www.myturbodiesel.com/1000q/a5/2009-2010-VW-TDI-fuel-filter.htm
Nice 2micron setup. Looking forward to additional products from Andrew.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old March 12th, 2013, 15:16   #39
CBRacerX
TDI(s): JSW 2010
I have the Andrew created "original" return filter option sitting in the garage waiting for the 60K filter change (almost at 50K now). If Andrew has a better option at that time I am all for it! If not, the 5 micron is going to be a huge improvement over NO return filter.
CBRacerX is offline   Reply With Quote
Old March 18th, 2013, 13:06   #40
rs999
Fuel Economy: www.fuelly.com/driver/rs999gti
Any update on this filter? How is testing and fitment of the V2 system going?
rs999 is offline   Reply With Quote
Old March 18th, 2013, 13:31   #41
JSWTDI09
JSWTDI09's Avatar
The Ver. 2 filter kit is almost ready to ship. There is more info and some pics in this thread (starting with post #150): http://forums.tdiclub.com/showthread.php?t=371988
More pictures here (including pics of the new "Pure Flow" HPFP modification): http://forums.tdiclub.com/showpost.p...&postcount=241
Unfortunately all the info on (and pics of) Andrew's modifications are spread out over several threads.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old March 19th, 2013, 14:06   #42
steve05ram360
TDI(s): 2011 2D Golf
What about these from Raycor? Shallow depth, may fit. I am looking to get a pre injection pump setup.
http://oregonfuelinjection.com/search.php
steve05ram360 is offline   Reply With Quote
Old March 22nd, 2013, 05:10   #43
ndamico
ndamico's Avatar
if you are running it as a secondary filter, this would probably last you years:
http://nicktane.com/osc/product_info...products_id=48
it is good for 50k on a dmax with a 3 micron pre-filter. mk4 tdi by itself can go about 50k on it.
14 Passat SE 6-Speed
ndamico is offline   Reply With Quote
Old March 22nd, 2013, 09:24   #44
rs999
Neat Nicktane kit, anyone try using it on a MK6 TDI?
Old March 22nd, 2013, 10:21   #45
79TA7.6
79TA7.6's Avatar
Location: Live: Wilbur/Creston; Work: Moses Lake Washington
The last two posts should not be in this thread. Nick, it sounds like you are advertising your product on someone elses thread. I am sure this was not your purpose, but that is how it comes across to me. RS, find ndamico's vendor thread and ask there.
2003 Jetta 5 Speed 272K miles. Malone stage 3. Titan 502 big hole injectors. VNT17 turbo. BuzzKen 2.5" down pipe. Ventectomy, EGR and cooler delete, Euro Switch, Home made custom HID.
79TA7.6 is offline   Reply With Quote
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 18:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 17:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 07:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 06:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 23:08
Page generated in 0.16228 seconds with 11 queries
[Output: 131.38 Kb. compressed to 109.92 Kb. by saving 21.47 Kb. (16.34%)]
