Old December 20th, 2012, 03:39   #1
BCKCX2
TDI(s): 2002 Jetta
Fuel Economy: URL=http://www.fuelly.com/driver/bckcx2/jetta][IMG]http://www.fuelly.com/sig-us/59052.png[/IMG][/URL]
Default Battery drain only when doors locked
Anyone have a idea where to start trouble shooting? 2002 Jetta TDI, my battery will completely drain overnight or after 12 hours at work if I lock the doors. Either with the key in the door, the remote, or the button from the passenger door. If I leave it unlocked though no problems. Thank you any input
BCKCX2 is offline   Reply With Quote
Old December 20th, 2012, 07:49   #2
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
A volt meter and a schematic and a few minutes work should find the problem for you.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old December 20th, 2012, 08:13   #3
SyNtAxx
Fuel Economy: 54/45/38
When you lock the car...do you hear the horn beep to signify all doors are locked? If not, maybe one lock actuators is stuck or sticking causing a drain. Just a thought.
His: 2001 Jetta GLS 5sp. 700+800 Mile Club
RC Stage 2+3 Euro Sprint 520s
Hers: 2004 Jetta GLS Auto
SyNtAxx is offline   Reply With Quote
Old December 20th, 2012, 10:18   #4
Vince Waldon
Vince Waldon's Avatar
There's a factory TSB on how to quickly track down current drains, using a multimeter across the fuses, so you don't wake any sleeping modules and chase red herrings. The old-skool method of pulling all the fuses and measuring the current at each fuse doesn't work as well.
Searching "current drain TSB" or something like that would probably help you find the threads here.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old December 20th, 2012, 12:43   #5
BCKCX2
TDI(s): 2002 Jetta
I did check the amp pull using my meter between the battery and the positive cable and all was good. It seems to be intermediate, was hoping someone had this happen before with a quick fix. I'll keep looking thank you
Old December 20th, 2012, 12:52   #6
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
The CAN bus isn't going to sleep, i.e., going into low current standby mode, after a period of inactivity like it should. Something is keeping the CAN bus alive when it should be in sleep mode. Check for one of more broken wires in the wire harness to the driver's door, the usual culprit.
Good luck.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old December 21st, 2012, 18:33   #7
BCKCX2
TDI(s): 2002 Jetta
Thanx will go hunting.
Relay chatter when doors locked cada VW MKV-A5 Golf/Jettas 0 October 29th, 2012 11:40
Dead battery = locked out jcrews TDI 101 22 December 5th, 2007 12:11
Re: Horn No Longer Beeps When Doors Are Locked compu_85 VW MKIV-A4 TDIs (VE and PD) 0 October 5th, 2005 15:27
Re: Horn No Longer Beeps When Doors Are Locked spyglass VW MKIV-A4 TDIs (VE and PD) 6 October 5th, 2005 13:08
Horn No Longer Beeps When Doors Are Locked PDJetta VW MKIV-A4 TDIs (VE and PD) 6 September 19th, 2005 05:14
Page generated in 0.14961 seconds with 11 queries
[Output: 80.51 Kb. compressed to 69.78 Kb. by saving 10.73 Kb. (13.33%)]
