Old October 29th, 2012, 11:40   #1
cada
TDI(s): 2006 Jetta
Default Relay chatter when doors locked
Whenever I lock the doors, the yellow indicator light in all 4 door lock buttons flashes continuously and I hear a constant relay chatter. The relay sounds like it's coming from behind the steering column. This happens when I use the key fob or lock the doors manually. I'm concerned that if I leave the doors locked for any period of time, say over a weekend, that it'll drain the battery. Any ideas of what would cause this or where to start looking?
cada is offline   Reply With Quote
Does chatter at idle=chatter below 1800 rpm? Milage King TDI Power Enhancements 11 June 9th, 2011 20:56
hazard swith relay chatter? afarfalla VW B5 Passat TDIs 3 September 22nd, 2009 04:58
Re: Horn No Longer Beeps When Doors Are Locked compu_85 VW MKIV-A4 TDIs (VE and PD) 0 October 5th, 2005 15:27
Re: Horn No Longer Beeps When Doors Are Locked spyglass VW MKIV-A4 TDIs (VE and PD) 6 October 5th, 2005 13:08
Horn No Longer Beeps When Doors Are Locked PDJetta VW MKIV-A4 TDIs (VE and PD) 6 September 19th, 2005 05:14
Page generated in 0.11562 seconds with 11 queries
[Output: 45.89 Kb. compressed to 43.22 Kb. by saving 2.67 Kb. (5.82%)]
