Old March 16th, 2012, 04:50   #1
EuroTuning
TDI(s): 2,0TDI
Default 6 speed conversion kit
Our company makes conversion kits from 5-gear to 6-gear. We have more than 10 years of experience with these modifications, so we know that designing and manufacturing of gears systems with VW quality to be reliable and without any noise is not easy at all...
Our solution makes it possible for experienced service workshop to carry out this modification without removing the gearbox out of the car. Our company usually performs this modification in 3-5 hours. Customers come in the mornings and leave in the afternoons with their 6-speed gearbox...
Kit price 1450$, shipping USA, Canada 130$
Conversion kit
http://www.eurotuning.cz/images/file...ion_kit_us.pdf
Installation instructions
http://www.eurotuning.cz/images/file...structions.pdf
VW tuning mag article
http://www.vwtuningmag.com/gearbox-conversion-kit/
Intructions for installation without removing the gearbox
http://www.eurotuning.cz/images/file...shift_rail.pdf
EuroTuning is offline   Reply With Quote
Old March 16th, 2012, 04:58   #2
silverbox
silverbox's Avatar
Fuel Economy: 55mpg highway@100kph
This looks interesting, what ratios are you using for TDI's
KERMA tune, PDliftpump,11mmIP Race 520's. PD150 Intake manifold&TIP, 1722 turbo, Upgraded IC pipes and Eurojet SMIC.Stealth racepipe. 2.5DP+catback areoturbo2525 muffler. Peloquin LSD.
Koni FSD's +VR6 springs, 23mmRSB, 16x7w/Conti DWS. GLI Recaros, Wingnut short shifter, Ecodes w/relays+60/100h4's.
Cat2 Fuel filter DG/Amsoil Bypass filter
silverbox is offline   Reply With Quote
Old March 16th, 2012, 05:11   #3
silverbox
silverbox's Avatar
I found the info in the PDF.
Old March 16th, 2012, 07:27   #4
LNXGUY
LNXGUY's Avatar
Very cool!
Bill
LNXGUY is offline   Reply With Quote
Old March 19th, 2012, 10:16   #5
drklawz
Default a fool and his money...
I would be interested in "piloting" and reviewing one of these kits for the US TDI audience.
Do you have an english language manual for the installation? I want to review with my shop and see if they are comfortable with the install.
How much additional would shipping be to US - 80301, ground?
drklawz is offline   Reply With Quote
Old March 19th, 2012, 12:40   #7
dieselpower04
dieselpower04's Avatar
Wow there was talk of this a long time ago in the USA, lets see if it works!
Gone but never forgotten...
My TDI Build Thread
dieselpower04 is offline   Reply With Quote
Old March 19th, 2012, 13:51   #8
yatzee
yatzee's Avatar
TDI(s): see sig
I'm already running a .658 6th gear - can the gear be reused? Also, does the kit basically slot a gear between 4th and 6th (if you consider what my ratio's currently are)
2005 C230 6 spd, 2001 GMC LB7 w/ZF6, 1994 E280 5 spd, 1990 500SL and some euro 16v stuff. No TDIs in the fleet for now
Please use the search function
yatzee is offline   Reply With Quote
Old March 20th, 2012, 11:46   #9
john.jackson9213
TDI(s): 1996 B4V
Go to his web site, then use Google to translate to English. For the TDI it looks like the factory fifth ratio is retained and a longer 6th gear is added. several ratios mentioned.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old March 21st, 2012, 14:47   #10
EuroTuning
TDI(s): 2,0TDI
I don't understand your question, write me your car model, year of production, engine type, gearbox code and we will send you the optimal solution for your car.
Old March 22nd, 2012, 05:50   #11
bagdwag
Banned
I sent in my info and basically what he told me is that 1-5 are the same and then the 6 would reduce rpms by 500-600rpm...
bagdwag is offline   Reply With Quote
Old March 23rd, 2012, 14:02   #12
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Just need someone that will install one.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car-4 door, 1.9 TD aaz, 5 spd
1981 Caddy VW truck-Topper with it
2004 Golf-2 inch lift, Q-loader stage 1 tune
Vag-Com owner
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old March 28th, 2012, 07:06   #13
PhunkFX
PhunkFX's Avatar
Fuel Economy: 44-46 MPG
Man, I want this. I wish my car hadn't decided to run away recently....
-Ricky
2005.5 VW Jetta TDI 6MT | 179K Miles |
PhunkFX is offline   Reply With Quote
Old March 28th, 2012, 10:16   #14
Losha
Losha's Avatar
Mind sharing how your TDI ended up running away from you? What caused run away?
VDUB Auto Repair www.vdubauto.com
Malone Tuning Dealer for SD, ND NE, IA, MN
'06 Jetta TDI DSG - Malone tune, Bilsteins B6, H&R Sport Springs, GLI front end, HID
Losha is offline   Reply With Quote
Old March 28th, 2012, 14:55   #15
PhunkFX
PhunkFX's Avatar
http://forums.tdiclub.com/showthread.php?t=346742
-Ricky
FS- 02J 5 speed Manual Tranny conversion kit w/ LSD & 3.16 R&P for Modded car tothemax Private TDI Items for Sale/Wanted 15 January 31st, 2011 17:56
WTB: 6-speed conversion kit 02M X@V Private TDI Items for Sale/Wanted 0 January 20th, 2010 11:00
01m to 5 speed conversion kit bryanbryan89x Private TDI Items for Sale/Wanted 2 August 7th, 2009 17:33
Looking for 5 speed swap kit, Shock/struts and TB kit GTA or Canada barriesr/t Private TDI Items for Sale/Wanted 0 January 1st, 2009 08:07
greasecar conversion kit mrup TDI Conversions 1 October 31st, 2006 23:32
Page generated in 0.18114 seconds with 11 queries
[Output: 134.06 Kb. compressed to 111.91 Kb. by saving 22.15 Kb. (16.52%)]
