Old March 10th, 2011, 16:31   #61
larsbar
TDI(s): 2002 Golf
Wow. So the shop screwed up, refuses to own their mistake, promises you a refund, doesn't give it, and threatens to withhold it if you tell anyone else about their mistake?
Even if they own up and pay for it now I would not trust someone like that.
larsbar is offline   Reply With Quote
Old March 11th, 2011, 14:37   #62
ryanp
ryanp's Avatar
Post #11
Edited as the shop has started to make payments to put this right.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is online now   Reply With Quote
Old March 11th, 2011, 15:07   #63
NoJoke
If I were to mediate this; I would put the offending shop on a monthly payment plan. If they reject or default, the customer needs to take them to small claims court for the provided parts and labor paid.
97 B4v ALHcompoundT's GLX AWD conversion
06 E320 CDI - RC
NoJoke is offline   Reply With Quote
Old April 16th, 2011, 15:08   #64
ryanp
ryanp's Avatar
Post #12
Old April 16th, 2011, 15:38   #65
foxracer1
foxracer1's Avatar
Fuel Economy: Low34/Avg40/best54
Well done!
15Passat DSG SEL stock for now 33k mi
06 Jetta DSG 246k mi Malone stg2 egr cat delete 18" Audi Flat Fives got totaled and I bought it back. Soon to be fixed.
04.5 Ram 2500 Cummins 4x4 6spd crew cab short bed 174k mi
Vag-Com owner
foxracer1 is offline   Reply With Quote
Old April 16th, 2011, 15:41   #66
Milage King
Milage King's Avatar
Fuel Economy: 40 / 46
This is really a mis fortunate situation, but I think the rest of the community will thank you for knowing who did the butcher work and hopefully save some headaches for other fellow club members. Sorrry Ryan.
03 Jetta - stg 3 TD Tuning, full speed density.
Milage King is offline   Reply With Quote
Old April 16th, 2011, 16:56   #67
AARodriguez Corp.
AARodriguez Corp.'s Avatar
I would love to see this club put together a fund to pursue bad shops, and engine killers like Prothe, I would donate to that fund in a minute
AARodriguez Corp. is offline   Reply With Quote
Old April 16th, 2011, 17:06   #68
BleachedBora
BleachedBora's Avatar
Likewise, I get calls all the time from people that have thrown on Prothe/Rothenbacher engineering parts only to have them x-plode.
Good luck Ryan, sorry to hear that the troubles are ongoing.
-BB
BleachedBora is offline   Reply With Quote
Old April 16th, 2011, 17:12   #69
DSLFAN
TDI(s): 01 Beetle
Too bad we can't do like in the 'ole days and have ourselves a little blanket party down in AZ - 8)
DSLFAN is offline   Reply With Quote
Old April 16th, 2011, 17:19   #70
AARodriguez Corp.
edit, for now...
Old April 16th, 2011, 18:29   #71
Derek@Exklusiv
Here's my side of the story - We installed 2 of these swaps on 2 of the same customers cars. The first one went fine with exception to a shift cable that arrived bent - likely due to the careless handling at customs. The parts were no longer palletized when arrived. The second one (one in question) was completed late in the evening on a Friday and I came in the following day to find the car on our lot and it seemed to be stuck in gear. Not uncommon for 02M's with broken shift fork. After much deliberation the customer and I decided to take the tranny to my tranny guy who split the case and just said this tranny is wrecked. I wasnt there, I didnt see it with my own eyes but he never mentioned it was dry which I would think he would just looking at these pictures. Ryan P just stepped up and sent out a replacement which we installed. It seems to me about 3 or 4 weeks later the customer stops in and shows me this thread of a tranny that is burned up and I'm led to beleive that it's the tranny that was sent back. I basically agree to pay for it to prevent some bullsh*t witch hunt thread like this. However the timing was bad as I had just been scammed for nearly $3000 dollars from a customer where I spent nearly 2 days installing an insane mount of OEM Euro parts on his Audi and paid for it with a stolen credit card. I spoke with Ryan last week and told him I was hoping to sell my personal car to cover the costs which hasnt happened. Since the original install I've sluffed off all the helpers I had and I'm back to a one man show doing some of the best work in Phoenix for TDI customers. I reluctantly take responsibility for this rare (1 and only) mistake and am willing to pay for it but you can't get blood from a rock. Most independent shops are running pretty lean these days and threads like this don't help.
If you want an accurate depiction of my shop, the work we do, and satisfaction of my customers all you have to do is search "Exklusiv" on this very website tdiclub.com
Derek@Exklusiv is offline   Reply With Quote
Old April 16th, 2011, 18:34   #72
Derek@Exklusiv
Originally Posted by Mach1 View Post
Hey its easy to get side tracked, I just try to make sure that
1) I check the level
2) I dont stop in the middle of checking it, either I start it/perform it/finish it, or I take the plug stick it in my pocket, that way the car is not getting off the lift without being done.
3) I check visual for 3 times to ensure parts got put back on..
Check, recheck, triple check..
Still some get through, but it does limit how many fall through the crack..
That's brilliant
Old April 16th, 2011, 18:37   #73
K5ING
Mega-Miler
K5ING's Avatar
Fuel Economy: 46 mixed/51 highway
Originally Posted by PDJetta View Post
I always thought transaxles (and engines) void of lubricant should have a BIG dayglow tag afixed to them stating "This Unit Has No Oil and Must Be Filled With Proper Lubricant Before Use" (or similar wording). It should be common sense to check, but NEVER underestimate the power of human stupidity. You are better protected if you put such a tag on the unit, because if it comes back to you, you warned them and it is their fault.
I bought a used transaxle once and it had such a tag, but it was still full of lube! (I guess they forgot to drain it).
--Nate
Stupidity carelessness is everywhere, and I agree with having a warning label.
A number of years ago, when I busted my oil pan (no damage, it was shut down within 20 seconds) and had the car towed to the dealer, I made sure I taped a big piece of paper to the steering wheel that said "WARNING! NO OIL IN ENGINE! DO NOT START!!!!" on the assumption that they would just tell their lot boy to "bring that silver Golf into the garage", and he would try to just drive it in.
Props to Derek for admitting the mistake too. In this day and age, it's refreshing. However, you really need some insurance to pay for stuff like this when it happens.
Silver 2001 2 dr. Golf GL TDI 5-speed (original owner)
445,000+ miles and climbing!
SOLD 10/2017 to member alphaseinor. It's in good hands.
DFW TDI List
K5ING is offline   Reply With Quote
Old April 16th, 2011, 19:30   #74
AARodriguez Corp.
-Have you made any payments towards that $3k, even $100?
-What date this fiasco start?
-What date did you, Dereck, acknowledge responsibility?
-If you haven't been given a reasonable amount time make a payment, tell us.
Yeah its a great idea a warning label, just like our coffee at McDonalds, we need a label telling us that our drink is hot, and could burn us. We are that dumb.
I can find plenty of people willing to admit they made a mistake, finding the ones that are going to correct it is the hard part. I don't know a whole lot about liability insurance, but I'd be willing to take a guess that the deductable for a mechanic shop could be over $2500.
Old April 16th, 2011, 19:38   #75
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Bottom line, you don't install a transmission of ANY kind without checking the fluid.. EVER.. You don't need a big yellow tag to tell you to check the fluid..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Page generated in 0.14911 seconds with 10 queries
[Output: 134.26 Kb. compressed to 111.61 Kb. by saving 22.65 Kb. (16.87%)]
