Old December 2nd, 2010, 22:35   #31
tothemax
tothemax's Avatar
Originally Posted by ryanp View Post
We are not naming and shaming the garage as we are giving them the opportunity to put things right (even though they stripped the box down and gave up half way through)..
Ry
Hey Ryan,
Can you tell us if the garage is state side or UK?
tothemax is offline   Reply With Quote
Old December 3rd, 2010, 01:34   #32
ryanp
ryanp's Avatar
Edited as the shop has started to make payments to put this right.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old December 3rd, 2010, 05:54   #33
Scott_DeWitt
Scott_DeWitt's Avatar
Originally Posted by Whitbread View Post
At bare minimum it needs all new bearings and syncros. Hopefully a brass brush will clean all the crap off the gears and they'll be ok. Whether that's cost effective or not, now that's a different story.
Looking at the gear teeth you will have to replace some gears, or they will be very loud.
I could use the cases, but that gearbox is toast.
so, that trans is garbage then? or can it be rebuilt?
It can be rebuilt however it's likely not cost effective.
Originally Posted by PDJetta View Post
I always thought transaxles (and engines) void of lubricant should have a BIG dayglow tag afixed to them stating "This Unit Has No Oil and Must Be Filled With Proper Lubricant Before Use" (or similar wording). It should be common sense to check, but NEVER underestimate the power of human stupidity. You are better protected if you put such a tag on the unit, because if it comes back to you, you warned them and it is their fault.
I bought a used transaxle once and it had such a tag, but it was still full of lube! (I guess they forgot to drain it).
--Nate
I ship a dozen gearboxes a month and all have a bright pink tag in big letter stating the trans is shipped dry. I even go as far as keeping the drain plug loose, and there are still 3-4 people a year that run my gearboxes with too little or no fluid. If you make something idiot proof there is always a better idiot that comes along.
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old December 4th, 2010, 18:09   #34
DSLFAN
TDI(s): 01 Beetle
Wow! Must've had a tweeker put that trans in! All used components we get are ALWAYS empty! Shipping companies won't even take stuff that has fluid in it, even local UPS.
DSLFAN is offline   Reply With Quote
Old December 4th, 2010, 19:23   #35
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
Originally Posted by Windex View Post
I would name the shop. It's asinine to assume that a shipped transmission has fluid in it.
The pics, let alone the odour, confirm that the transmission was run without oil.
The tech messes up and needs to man up for their mistake.
No two ways about it.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old December 4th, 2010, 19:41   #36
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Anbody/anyshop, that installs/replaces a transmission...Absolutely knows to check the level..
Even if no fluid is spilled, disturbed, or changed...check the level.
Heck I check the transmission just for courteous jesture when their car is on the lift..
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old December 4th, 2010, 20:32   #37
Reddok
Reddok's Avatar
Fuel Economy: Jetta: 40.8 avg, 47.1 best. Jeep: 30 avg.
I wonder how often stuff like this happens. Thats how I got my project Jeep for such a good price. The previous owner had assumed the transmission was shot because the Jeep wouldn't move. I pulled the trans and transfer case and found the transfer case (with wrecker pen markings on it) was completely dry. Should have taken some pictures. The planetary gearset looked much the same as the picture above. I'm sure it smelled the same too...
2000 Jetta 01M: Ventectomy, Snowscreen removed, Injection timing advanced, EGR dialed back.
2002 Jeep Liberty TDI Project: 2002 ALH, 1749VA, NSG-370 6-spd, PP764's on T4's, 11mm pump, PD150 intake, custom tune, Cummins lift pump, 2.8 CRD intercooler, 2.5" DP/exhaust with Magnaflow cat and Walker Quietflow muffler.
Reddok is offline   Reply With Quote
Old December 4th, 2010, 22:52   #38
Whitbread
Whitbread's Avatar
TDI(s): Several
You would think so. I was told this shop is even on the "trusted tdi shops" list.
I don't know the name of it though so I can't comment there, I'm curious myself.
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old December 5th, 2010, 06:47   #39
ChippedNotBroken
Fuel Economy: 50,45
I'm sure we've all made boneheaded mistakes.
I've found that it's not the mistake, but the response to the mistake that's important.
Of course that presupposes a level of competence that would suggest a lapse like this is just that, and not another in a long line of incompetent acts.
1999.5 Green Jetta MrChill'd and Wild Bill'd then it got the Whitbread build, Bleached 'n Nick'd and idi'd, RC'd, RyanP'd then fine'ly Jasonified.
Youtube video of smoke
Youtube video of vacuum restriction
Errors of opinion may be tolerated where reason is left free to combat it. TJ
ChippedNotBroken is offline   Reply With Quote
Old December 6th, 2010, 09:17   #40
ryanp
ryanp's Avatar
Post #7
Old December 6th, 2010, 13:35   #41
Whitbread
Whitbread's Avatar
TDI(s): Several
Very true. We've all left a bolt or two loose before (I'm guilty) when in a hurry, interrupted, etc.
It could have been one of those things. The apprentice forgetting or if they got interrupted half way through, who knows.
Nobody needs to know which shop this is as long as they make all this right (which we are getting somewhere).
Ry
Even when they make it right, its still sad to see a rare trans destroyed .
02 Jetta TDI
Old December 6th, 2010, 17:11   #42
DSLFAN
TDI(s): 01 Beetle
So true!
Old December 7th, 2010, 01:58   #43
Mach1
Hey its easy to get side tracked, I just try to make sure that
1) I check the level
2) I dont stop in the middle of checking it, either I start it/perform it/finish it, or I take the plug stick it in my pocket, that way the car is not getting off the lift without being done.
3) I check visual for 3 times to ensure parts got put back on..
Check, recheck, triple check..
Still some get through, but it does limit how many fall through the crack..
2004 6L 89000 19MPG
Old December 7th, 2010, 04:37   #44
ChippedNotBroken
Fuel Economy: 50,45
Back in the 80's I was going to go on a ski trip and figured it would be a good time to change my oil the night before.
I always used to rub some motor oil on the gasket for a better seal before re-installing the gasket and putting it on the car (filter was under the car).
The next morning we hopped in the car (5AM) and headed on our way. Couldn't have been 2 minutes down the road and the oil light came on. Two hours, 5 quarts and another oil filter later we were on our way. Can't say how it happened, but I put the filter on without the gasket. My daughter calls them brainfarts.
Old December 7th, 2010, 07:38   #45
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Yeah I think we all do it from time to time.. I've gotten sidetracked doing oil changes in the past and noticed the lack of a rain plug while filling the oil. "Why the F is it all on the floor? Oh... Probably because the drain plug is over there..." Things like that usually only happen once, like the extra oil filter gasket that stayed up there when you pulled off the old filter.. That doesn't last long at all..
The worst thing on my part is forgetting to put engine covers back on.. I do it at least once a week.. Most of my customers don't have them on anyway, so I forget and a day or 2 later I see an engine cover laying in the shop and wonder who's it is.. Usually that coincides with a phone call inquiring about a missing engine cover..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Page generated in 0.15655 seconds with 10 queries
[Output: 137.92 Kb. compressed to 115.55 Kb. by saving 22.38 Kb. (16.22%)]
