Old December 2nd, 2010, 04:39   #16
PDJetta
PDJetta's Avatar
I always thought transaxles (and engines) void of lubricant should have a BIG dayglow tag afixed to them stating "This Unit Has No Oil and Must Be Filled With Proper Lubricant Before Use" (or similar wording). It should be common sense to check, but NEVER underestimate the power of human stupidity. You are better protected if you put such a tag on the unit, because if it comes back to you, you warned them and it is their fault.
I bought a used transaxle once and it had such a tag, but it was still full of lube! (I guess they forgot to drain it).
--Nate
Old December 2nd, 2010, 04:39   #17
ryanp
ryanp's Avatar
Post #2
Edited as the shop has started to make payments to put this right.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old December 2nd, 2010, 04:52   #18
jimbote
jimbote's Avatar
Originally Posted by Whitbread View Post
I suppose I should've clarified further in the first post. This trans came from RyanP, was installed by a shop, locked up shortly after installation, then was pulled and shipped to me to see what happened.
Anytime a trans is ran, pulled, drained, and then shipped, it will always be "wet" inside. The first pic I posted of a 5 speed that was shipped to me for upgrading is a perfect example; notice the coating of oil on everything even though it was empty when it got to me. This 6 speed was BONE dry inside with the acrid odor of burnt gear oil.
At bare minimum it needs all new bearings and syncros. Hopefully a brass brush will clean all the crap off the gears and they'll be ok. Whether that's cost effective or not, now that's a different story.
you may want to do a file test on the gears before you order any bearings...a good hardened gear will shrug off a file stroke but a gear that has lost it's hardness will take a cut from a standard file....
jimbote is online now   Reply With Quote
Old December 2nd, 2010, 05:35   #19
ChippedNotBroken
Fuel Economy: 50,45
--Nate
Ever look at the warning stickers they put on the bottom of candles here in the US?
Warning lit candle can be hot, do not burn under drapery or other flammable material.
1999.5 Green Jetta MrChill'd and Wild Bill'd then it got the Whitbread build, Bleached 'n Nick'd and idi'd, RC'd, RyanP'd then fine'ly Jasonified.
Youtube video of smoke
Youtube video of vacuum restriction
Errors of opinion may be tolerated where reason is left free to combat it. TJ
ChippedNotBroken is offline   Reply With Quote
Old December 2nd, 2010, 06:09   #20
NoJoke
Lets turn this frown upside down....I'll take the gears if they are intact and send them to get cryo treated. I got an R32 awd trans for that!
97 B4v ALHcompoundT's GLX AWD conversion
06 E320 CDI - RC
NoJoke is offline   Reply With Quote
Old December 2nd, 2010, 06:17   #21
ryanp
ryanp's Avatar
Post #3
Old December 2nd, 2010, 06:56   #22
john.jackson9213
TDI(s): 1996 B4V
Originally Posted by Sprocket View Post
I know Matt didn't run his tranny dry and I'm sure this is one of his customers. Yes, you would think that it would be common sense to double check fluid levels before starting the car and driving it
So, can you bring her back to life Matt?
Common sense is not that common!
john.jackson9213 is offline   Reply With Quote
Old December 2nd, 2010, 08:32   #23
ryanp
ryanp's Avatar
Post #4
Old December 2nd, 2010, 10:19   #24
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
The fact that it was dry when you took it apart was most likely from the extreme heat generated while driving it with only 14 drops of fluid in it.. I've taken apart a few rear axles that were run dry, dry like pull the diff cover to drain, put the cover back on and drive until it stops, and it's the same thing. bone dry like it never had fluid and the nastiest small of burnt gear oil..
I bet it was drained prior to shipping and the shop just never bothered to check it..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is online now   Reply With Quote
Old December 2nd, 2010, 10:27   #25
ryanp
ryanp's Avatar
Post #5
Old December 2nd, 2010, 10:46   #26
jimbote
jimbote's Avatar
Ha ha...seven people viewing ...it's like the onlooker delay's when there is a gruesome wreck scene
Old December 2nd, 2010, 18:41   #27
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Props to you Ryan! This isn't your burden, not by a long shot.
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old December 2nd, 2010, 19:15   #28
oldpoopie
oldpoopie's Avatar
Oooh big install fail.....
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old December 2nd, 2010, 19:35   #29
Dakta
Dakta's Avatar
TDI(s): Non Vag :(
Fuel Economy: approx 50
I once had a pickup that had it's gearbox go, had it replaced by the same people who service our HGV's and 300 miles later it was scrap.
No oil. As a matter of fact they'd lost the filler sealing bolt too.
Wasn't impressed.
Dakta is offline   Reply With Quote
Old December 2nd, 2010, 19:53   #30
oldpoopie
oldpoopie's Avatar
fwiw....
http://forums.tdiclub.com/showthread.php?t=301150
Page generated in 0.19021 seconds with 10 queries
[Output: 132.60 Kb. compressed to 110.10 Kb. by saving 22.50 Kb. (16.97%)]
