Old July 3rd, 2017, 13:04   #601
Turbo Z
the higher the inlet stage temperature to a compressor stage the work is direct proportional to the temperature increase.
If you compress air at 83k at pr 5 at isentrop condition (say cp=1000j/Kkg)
the needed specific work is about 50kJ/kg air
if we rise the temperature to the double 166K the needed work for compression is about 100kJ/kg, the double amount of work for compression, the opposite can be used in turbine, the higher the temperature the more work is available for abstraction from the stage
actually a isotherm at normal temperature is the operation that will need the smallest amount of specific work, but not so easy to do in real, interstage cooling is between, and yes you can supercool the air by a Brayton cycle to -0--30 degree celsius, the same method used in air condition in airplane. But will need more exhaust pressure and ALOT of other thing to think about.
but inter cooling has another positive thing, since you keep temperature down the viscosity of the air is lower (viscosity for gases increase with temperature)
this mean we will have a higher Reynolds number in second stage then without intercooling and the air will follow the blade better in the compressor and by that work better, and more margin for surge. The generalize parameters does not take this into account as fare as I know but I can be mistaken there.
and do not forget the higher the pressure ratio in general the lower efficiency, the pollytropic efficiency is the same. This because the isentropic efficiency is less then 100%, so the more to the end you end up the more work is needed all the time because temperature is increasing.
Turbo Z is offline   Reply With Quote
Old July 3rd, 2017, 13:49   #602
turbobrick240
turbobrick240's Avatar
I'm not sure if the metallurgy would be happy with 83 K .
Old July 4th, 2017, 11:07   #603
Rub87
nice, thats maybe also one of the reasons why pre comp wi works so good.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old July 5th, 2017, 19:23   #604
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
When you inject water pre-compressor, the gamma is not longer that of air (1.4) but a lower value. That helps reduce compressor work, but simultaneously increases the mass flow, so it is neither clear nor always the case that pre-comp WI "works so good". It's definitely very bad for other things, like pitting the compressor wheel.
Old August 5th, 2017, 17:36   #605
KLICHO
TDI(s): 1z
Hello. I search information about 3 turbo's GTD1549vz GTC1549vz and BV43A i need informaton
intake:
inducer:
exducer:
AR
exhaust
inducer :
exducer :
KLICHO is offline   Reply With Quote
Old August 6th, 2017, 23:59   #606
kristsm
Hi!
Can someone please share turbine & comp. wheel measurements of latest VNT gen GTD2060VZ / VZK ? Someone said to someone its size is larger than the previous gen GTB2260 (which obviously contradicts with the nomenclature of GT20 < GT22). Is it true?
Thank you!
kristsm is offline   Reply With Quote
Old August 7th, 2017, 02:47   #607
ryanp
ryanp's Avatar
GTD2060 - turbine is smaller, compressor has 63mm extended tip. They work well but not night and day compared to older GTB2260. GTD1752vrk on the other hand is VERY good.
I'm going to test GTD2263vzk, hopefully it makes more power
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old August 7th, 2017, 04:11   #608
kristsm
Nice! Have you installed GT22V turbine wheel in the GTD2260 and upgraded comp wheel with KTS china cnc'ed wheel? Thank you!
BTW , does GTD2060 tolerates higher EGT's than GTB (It should as I understand from Garrett official videos)?
Old August 7th, 2017, 07:36   #609
KLICHO
TDI(s): 1z
intake:
inducer:
exducer:
AR
exhaust
inducer :
exducer :
Nobody knows ?
Old August 10th, 2017, 19:56   #610
3L3M3NT
3L3M3NT's Avatar
Ryan any chance you're coming out with a kit for 1.9/2.0 TDI that will utilize the GTD1752vrk? It just seems like the perfect turbo for our engine.
Sturgeon Bay, WI GTG/Cruise October 21st, 2017
http://forums.tdiclub.com/showthread.php?t=480490
3L3M3NT is offline   Reply With Quote
Old August 11th, 2017, 01:03   #611
ryanp
ryanp's Avatar
Its a possibility but this would be a little more expensive to build than a normal GTD2260 kit so as long as there is a market we can do it!
Old August 11th, 2017, 07:56   #612
sam-
Hello,
As you mention GTD2260 and garrett website refering size up to GTD22, i bet its oem turbo but on which car please ? I own a GTD2060VZ actually.
Also would you share some info about the turbo you're using on the arosa (GTD2874VR) please ?
Thanks in advance
sam- is offline   Reply With Quote
Old August 16th, 2017, 20:52   #613
3L3M3NT
3L3M3NT's Avatar
Any more info on the GTD2260 kit, since I've heard the new GTD series turbos respond better than the older ones did. I'm looking into the future on what to replace my VNT-17/22 with and I was originally thinking the GTD1752vrk would be the perfect turbo for a daily driver, but now you have me intrigued by the GTD2260 kit.
Old October 2nd, 2017, 03:28   #614
fergyp
Does any no induced exducer on gtc1549vz
fergyp is offline   Reply With Quote
Old October 2nd, 2017, 03:30   #615
X-Man
X-Man's Avatar
36.4mm
TDI turbochargers for less
turbos@xman750.co.uk - GTB1756vk, GTB2260vk, 1.9TDI hybrids and more...
www.facebook.com/XMan-Turbos
X-Man is offline   Reply With Quote
Page generated in 0.18510 seconds with 10 queries
[Output: 131.07 Kb. compressed to 109.64 Kb. by saving 21.42 Kb. (16.35%)]
