Old May 23rd, 2017, 10:15   #31
adamss24
Fuel Economy: 35-45mpg
Well done !
adamss24 is offline   Reply With Quote
Old May 23rd, 2017, 14:27   #32
martin33100
TDI(s): VW T5 2.5
That's good going diffas, I sent you and adams24 a PM earlier as I want to pick your brains one last time before I order up my manifold bends and pipe etc.
martin33100 is offline   Reply With Quote
Old May 24th, 2017, 03:40   #33
Layerz
Geez I bet that shifts! Shocked how far along the power lasts too.
Layerz is offline   Reply With Quote
Old May 24th, 2017, 08:03   #34
diffas
diffas's Avatar
It goes quite good. I try to make some video out of it next weekend.
Thing is that this with is same ecu-file that gave on dyno 343hp last autumn. Only some hardware mods done.
It's far from perfect. At least not that smoky anymore. Tq limiter kicks in around 5400rpm decreasing fueling til
5900rpm. Maybe less limiting and more fuel up to 6000. :P
Fun data sheet from the run:
diffas is offline   Reply With Quote
Old May 24th, 2017, 17:19   #35
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Very nice. So... what turbo and injectors? Stock pump?
Old May 24th, 2017, 23:23   #36
diffas
diffas's Avatar
Mods i've made in past year is custom valve springs, biggest (600x300x76 core) fmic i was able to fit without destroing bumper that much. Also installed external lift pump 370lph@1.2bar. V-pump is modified years ago installing 3plunger high pressure Ake pump head. Nozzles are still the same cpc ones since atm nothing else is not available.
And the turbo is Fin-turbo made kkk/bw-s200g-k26/27 hybrid. 52/74 mm (? if remember correctly) compressor and 70/59mm turbine shaft.
Old May 25th, 2017, 04:40   #37
Layerz
Is this with a mildly ported or heavily ported heads?
Old May 25th, 2017, 05:52   #38
diffas
diffas's Avatar
Mild porting since we didnt take any risk with blowing thru. Some cam upgrade is still possible to make but seems that stock cams perform quite good
Old May 26th, 2017, 13:05   #39
diffas
diffas's Avatar
Made a new video: https://www.youtube.com/watch?v=MYuU...ature=youtu.be
Old May 26th, 2017, 23:18   #40
adamss24
That's very clean ! Well done mate !
Old May 27th, 2017, 05:57   #41
Layerz
That sounds amazing! Need to get the sound of mine unleashed a bit more I think!
Old June 24th, 2017, 14:43   #42
diffas
diffas's Avatar
Did manage to run standing mile with new personal record.
Great video from the event organizer:
https://www.youtube.com/watch?v=5uNun4WA07k
Old July 1st, 2017, 23:06   #43
im570rm
just bought a week ago an a6 afb,needs more power def ,planning to repair/hybridize the turbo(since now is almost dead) ,seen a iveco turbine 1mm bigger the ake turbine also wheel have bigger inducer,should be good for my goal which is ~200 bhp or so.
I know that afb is the weakest of them all i was wondering did you guyz did anything else for 200-210 hp,without changing the noozles ofc.
Audi a6 avant 2.5 tdi quattro
EX Alfa romeo 156 sw 2.4 jtd with 2260vk water cooled
EX Seat Leon 1.9 TDI ASV
im570rm is offline   Reply With Quote
Old July 23rd, 2017, 19:13   #44
X@V
X@V's Avatar
CPC should reply to their message, it's a real joke...
Is Firad making nozzles for these V6?
Jetta 1985 PD150, crazy QUATTRO!
Audi A4 B7 Quattro : V6 TDI project
Jetta 2009 TDI dsg, GTB1756VK + custom tune = fun!
X@V is offline   Reply With Quote
Old July 24th, 2017, 07:25   #45
diffas
diffas's Avatar
For 200hp there is no need for upgrades. Since you are upgrading turbo anyway why not to upgrade it to support even bigger output like 250+. After remap you want more anyway?! It's never enough!
Page generated in 0.15845 seconds with 10 queries
[Output: 123.54 Kb. compressed to 102.29 Kb. by saving 21.25 Kb. (17.20%)]
