Old February 7th, 2007, 21:24   #1
Taz107
TDI(s): 06 Jetta
Default It's -44, and I want to leave car running and lock doors - how?
When I run in to get my coffee from the local coffee shop on my way to work, I want to leave my car running, and lock the doors...is this possible with any combination of regular keys, valet key, and remotes?????
Also, I have found the only way to increase the idle is to turn on all the electrical accessories, defrost, mirrors, seats, and fan. This only increases idle by 100 or 200 RPM. Is there another way?
Thought of putting in command start, but with the idle so low, it would be pointless...wouldn't it be neat, start it remotely, and increase or decrease the idle speed with the remote as well....
No "shouldn't leave your car idleing blah blah blah" please...it was -44 this week, can't see it being good to shut off the car after running for only 2 minutes....to start again 2 minutes later...
Taz107 is offline   Reply With Quote
Old February 7th, 2007, 21:32   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
This is where a drive-thru that sells good coffee would sure be nice!!
No solution here, but you have my sympathy. Sorry.
Please tell us, does your heater ever work and does your engine warm
up at all? Most of us will NEVER experience temps like yours..
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 7th, 2007, 21:38   #3
DrewD
I do this on occasion when I don't have time to do a proper 2 minute turbo cooldown. I use my valet key to manually lock door with my regular key in the ignition with vehicle running.
DrewD is offline   Reply With Quote
Old February 7th, 2007, 22:03   #4
Taz107
TDI(s): 06 Jetta
thanks, i will give that a try. When you say lock the door, you mean put the key in the door and turn, like the "old days" before everyone got key fobs???
My GM truck is nice cause i can start it with the normal key, and use the key fob to lock the door while it runs...
Heater Work? nope...have the front rad completly blocked and after 20 mins on the highway, lucky to get the temp gauge up at all, thank god for heated seats, or the car would have been sold months ago....
Old February 7th, 2007, 22:40   #5
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
A few minutes idle under those conditions is not a problem. Hope you have a garage and a block heater up there. If your garage is well built, small, I used a 8k btu Kerosun. It would run 34 hrs on 2.5 gals and I would start it just before midnight. At 6 am the garage was tolerable and one tank lasted all week. Great for warming tools and hands when working under those conditions. Kerosuns are very safe. Its cheaper than a block heater all night and you can set that by timer for 4 am. I also saw a battery heater at JC Whitney that can come on with the block heater, and OH you need the 0W oil. By the by the new 507 5W30 is actually better than than the 506.01 0W30 by 9 F.
You could use the Valet key in the ignition and the remote to unlock as you approach the car.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old February 8th, 2007, 05:20   #6
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
The second post from our freezing neighbors that reports temps at or below -40C (-40C = -40F).
I was curious about the freeze protection of our G12 antifreeze, so I googled around and found that a 50/50 mix of G12 is good to -29.5F.
Anyone else have any other sources, or numbers to share?
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old February 8th, 2007, 06:29   #7
RickD
Fuel Economy: So Far..50 m.p.g
Oddly,my remote won't work with a key in the ignition,motor running or not.
When I leave my car running,I lock it manually with the "second" key.
RickD is offline   Reply With Quote
Old February 8th, 2007, 06:47   #8
Taz107
TDI(s): 06 Jetta
Thanks, remotes seem to go "dead" when car is running...that is one of the first things I tried...
Old February 8th, 2007, 07:03   #9
Gaggu P
yup..remote goes dead when theres another key in the ignition...start her up with one key and use the other key to manually (turn) the lock to the locked position...
B5.5 BHW - 2005 Passat TDI GLS Black on Black Automatic with triptonic
- Ventectomy, Glow Plugs upgraded
- Technine Tuned Stage 1+ 18psi Approx 170hp - 310lbs/tq
- Gear driven Balance Shaft and timing belt at 166km
Gaggu P is offline   Reply With Quote
Old February 8th, 2007, 09:55   #10
wjdell
Thats why I and others will tell you 70% coolant -30% deinonized water. But its not advisable to go higher as water activates coolant - read at Zerox site very good. Although the manual says 60% max the bottle says 70%.
Old February 8th, 2007, 10:27   #11
weedeater
Fuel Economy: 54/43/38
I came across a Starbucks that had bought out and moved into a bank. They had turned the teller window into a drivethrough.
Nice.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old February 8th, 2007, 12:27   #12
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
With an Address in FLA, you probably mix the stuff in 1% increments.
Thanks for the info, I hope others can use it.
(50/50 is good for Michigan)
Old February 14th, 2007, 00:49   #13
itsmejerry
You can also lock the car by pressing the lock button on the passenger door and closing it after you do so. But again, you'll need a key to unlock the car.
itsmejerry is offline   Reply With Quote
Old February 14th, 2007, 00:54   #14
compu_85
Gadget Guy
compu_85's Avatar
On my A4, you can lock the car with another key while it's running using the slot on the outside of the drivers door.
-Jason
Present:
2013 Fiat 500e. 18,000 miles. Almost 100 miles per charge!
Past:
Old February 14th, 2007, 06:26   #15
bulabula
bulabula's Avatar
I've never tried it with the Jetta, but with my Cummins, I use a stick between the pedal and the seat to raise the idle. Guys with power seats have used the seat switch to vary the rpm....
Chris
'06 Jetta TDI; Pkg 1; White; 5-speed
'01 Golf TDI; 2 Door; Green; 5-speed
'03 2500 Dodge; Cummins HO/6 speed; 4x4; 4.10's
bulabula is offline   Reply With Quote
Page generated in 0.15093 seconds with 10 queries
[Output: 127.37 Kb. compressed to 106.24 Kb. by saving 21.13 Kb. (16.59%)]
