Old May 28th, 2003, 01:43   #16
RAVEN
Default Re: Is a GT1749V a VNT15 turbo ?
Guys has anyone fitted a VNT turbo as an upgrade from the non vnt type?? and if so whats the outcome!
RAVEN is offline   Reply With Quote
Old May 28th, 2003, 02:01   #17
AtomicSushi
Fuel Economy: 47/37/32
I haven't heard of that.
Fitting a bigger turbo would seem much easier with a wastegate turbo though.
AtomicSushi is offline   Reply With Quote
Old September 21st, 2010, 07:22   #18
ian-b
My vnt-15 is bad and I have a gt1749v to replace it with. I know it bolts up and all that. Will I be ok running it without changing anything else? Is the larger wheel a big enough difference to make me need to tune? The exhaust housing on my vnt-15 is in better shape. Can I put the gt1749v cartridge into my old manifold of did they change that with the 1749v too? Figured I would add to this thread because it's titled properly for these kinds of questions.
ian-b is offline   Reply With Quote
Old September 21st, 2010, 11:07   #19
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
Yes another tune would optimise it and give best driveability and fuel consumption.
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old September 21st, 2010, 11:21   #20
ian-b
I know it would be optimal. I'm new to diesels not tuning and turbos. I've build and tuned my own megasquirt for my subaru before. I just want to make sure I can get the car up and running and drive it a bit without issue. And I need to know if I can put my 1749v cold side and cartridge into the original vnt15 manifold. Are they different? The 1749 one I have has some messed up bolt holes I'd rather not have to monkey with. Anyone know?
Old September 21st, 2010, 11:45   #21
cog
Originally Posted by Anders View Post
No smoke right now. I have blown the turbo and I don't know which one I want. I will proberly get a VNT17 and see how that will work on my car.
I will also have the chip changed sp that I dont have 434 nm at 2000 rpm's. The driveability is not good right now. I want max nm at around 2500 rpm's.
the 110 works very well on its stock turbo and pp764 injectors and tune. but i can tell you the vnt 17 works very well in deed on the 110 if you give it enough fuel .
Now BMW 123d @ 272bhp
Formerly GT-TDI 110 AHF VNT 17VB[/B],@24psi ,,R520s,ported head,11mm pump,arp,headstuds,eurojet smic,id parts upgraded pipes,SBC[B] stage 3, pd150 manifold, custom silicone t.i.p 2.5"downpipe and cat delete,racepipe,,pd lift pump
cog is offline   Reply With Quote
Old September 8th, 2017, 17:18   #22
jackfolstam
jackfolstam's Avatar
Fuel Economy: 48mpg
seven more years!
jackfolstam is offline   Reply With Quote
Page generated in 0.11951 seconds with 10 queries
[Output: 75.19 Kb. compressed to 64.92 Kb. by saving 10.27 Kb. (13.66%)]
