Old August 28th, 2017, 15:08   #1
KillyMcGee
Default 01 TDI with 0 power, not limp mode
No codes
Replaced all vacuum lines
Swapped MAF sensor from my other TDI
Tested, then replaced VNT actuator because it wouldn't hold a vacuum
Removed snow screen
New fuel filter
New air filter
VCDS logs are attached. I can get whatever logs I need to troubleshoot this, just don't know what else to check.
Files:
https://ufile.io/fi8d0
https://ufile.io/8fmw2
https://ufile.io/4edjk
KillyMcGee is offline   Reply With Quote
Old August 28th, 2017, 15:23   #2
BobnOH
Fuel Economy: 50/45/35
Does the actuator move the turbo vanes? When you first start the car, it should move roughly an inch, closing the vanes.
BobnOH is online now   Reply With Quote
Old August 28th, 2017, 16:32   #3
KillyMcGee
Moves with a vacuum pump. Will check on startup
Old September 13th, 2017, 14:32   #4
KillyMcGee
Figured this out.
Finally gave a code for overboosting after replacing VNT actuator.
Took 15 minutes to adjust the VNT actuator arm length properly. Drove it and it def had more power than it did but was still very slow.
Turned EGR down in VCDS while I was at it.
IQ was on the upper limit of normal and VCDS already had it adjusted as far as it would allow. Did the hammer mod to get it in the 2 ballpark. MUCH much more power.
Updates to the car here: http://forums.tdiclub.com/showthread...84#post5327184
Old September 13th, 2017, 16:01   #5
BobnOH
All s
Stock VE car likes it around 2.2. If you're fussy you can bump it up some, see if it improves anything.
Thanks for posting back!
Questions with answers is what makes a forum great. Most folks only need search.
Old September 13th, 2017, 17:40   #6
UhOh
UhOh's Avatar
Messing with EGR adaptation is mostly useless. Look around and you'll find a thread talking about this.
UhOh is offline   Reply With Quote
Old September 14th, 2017, 13:39   #7
Nevada_TDI
Due to emissions regulations, our ALH's come set very lean, so adding a bit of fuel really does make a positive difference in the way they run. Bigger nozzles are the usual way, but taking the IQ setting down a bit most often helps too.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Help in Owen sound m4k tdi limp mode,power loss jessejames Ontario 2 August 17th, 2016 12:05
tdi slow/loss of power limp mode jmchugh588 VW MKIV-A4 TDIs (VE and PD) 6 October 23rd, 2015 09:37
01 tdi turbo over boost/ limp mode maximus2388 TDI 101 0 April 10th, 2014 19:33
Loss of power 01 Jetta TDI, not limp mode. HELP wakdady TDI 101 6 June 13th, 2008 18:34
01 Jetta limp mode problem Jay Proctor VW MKIV-A4 TDIs (VE and PD) 6 November 22nd, 2006 12:44
Page generated in 0.15933 seconds with 13 queries
[Output: 78.70 Kb. compressed to 68.32 Kb. by saving 10.38 Kb. (13.19%)]
