Old August 31st, 2017, 19:33   #1
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Default Lost power to my lift pump
Well my lift pump was intermittently working the last month, when it has issues I can feel the lift pump relay erratically going in and out. But now there isn't any power getting back to the lift pump. Also when it was having the power issue I pulled the relay housing out and was playing with the wiring to see if I could detect the culprit and it would seem to be fine, then when I reinstalled the housing it would start going in and out again. So I've had to just stick my old sending unit in there.
I've double check all my connections, 3 of them are soldered, and 2 have butt end connectors. Maybe I need to get rid of the butt end connectors and solder everything. It's been fine for 6 years. I've also changed the relay out with no difference.
2K jetta gl tdi 5spd 391k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old September 6th, 2017, 19:09   #2
turbovan+tdi
turbovan+tdi's Avatar
Sure the pump isn't bad?
1984 6.2 Diesel Get A Way van, remote turbo setup designed/installed by me, burning anything that burns.
2003 GSW, 2.0L ALH, Colt Cam, 1756 turbo, auto, silver, 380k-Wife's.
2004 GSW TDI, blue, 5 speed-DD-Malone stage 2, no kitty, aeroturbine muffler, PD150's.
2003 JSW 1.8T future TDI, silver. 2006 JSW, TDI 5 speed, blue.
turbovan+tdi is offline   Reply With Quote
Old September 6th, 2017, 20:06   #3
terrydtdi
terrydtdi's Avatar
When I pulled the pump out, I connected power to it and it runs. When I get a chance I'm going to see if I can chase it down. Hopefully I'll find the culprit.
Old September 6th, 2017, 20:47   #4
turbovan+tdi
Running the pump out of the tank and in the tank are 2 different beasts as the fuel creates a drag with can stop the pump from working, but when out of the tank and no drag, it will operate.
Old September 8th, 2017, 20:06   #5
terrydtdi
terrydtdi's Avatar
I ran the pump when it was full of fuel and it run stead with the amount of fuel that was in there.
Can a bad lift pump cause low power? AARodriguez Corp. VW MKIV-A4 TDIs (VE and PD) 14 June 2nd, 2012 15:23
PD lift pump wiring problem, no power in 100/53 relay sardo_67 TDI Power Enhancements 7 April 27th, 2012 06:06
Fuel Lift Pump not getting power OllieBrown VW MKIV-A4 TDIs (VE and PD) 6 January 20th, 2012 14:43
Lift Pump causing power loss? jlk TDI 101 9 April 12th, 2008 22:42
power lost after injection pump replacement - help! MrMark TDI 101 18 April 2nd, 2008 15:18
Page generated in 0.12540 seconds with 13 queries
[Output: 71.58 Kb. compressed to 63.31 Kb. by saving 8.27 Kb. (11.55%)]
