Old September 3rd, 2017, 16:33   #1
superhl
Default 1992 isuzu to diesel TDI swap
I have a 2002 1.9 diesel that I would love to install in my 1992 2.6l gas pickup space cab. The trans is MAU T-3. Whitbread thinks I need a 4.3v6 5 speed transmission to mount to the TDI. Anyone familiar with Isuzu 2.6l gas engines/transmissions?
superhl is offline   Reply With Quote
Old September 6th, 2017, 18:21   #2
Motohead1
Isuzu was mostly a chevy hodge podge so its most likely a SBC bolt pattern. EVguy has what you need if thats the case.
Motohead1 is offline   Reply With Quote
Old September 17th, 2017, 15:30   #3
superhl
Would I better off purchasing a toyota transmission and if so which toyota transmission? The TDI that I have came out of an automatic. I want a manual transmission. What else will I need. I would like to put it together for testing before installing.
Old September 18th, 2017, 18:14   #4
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
Like he said, hit up EVguys page/site. He has a variety of adapters so you can pick the tranny you want to use... Ford 3.0 or 4.0, Chevy SBC, I think he's working on a Toyota 22r adapter, some others I cannot recall.
If the current engine block uses the small block Chevy bolt pattern, then you can use that adapter and the current transmission.
2003 Jetta TDI - Boring daily driver for now...
1996 Passat TDI - "Red Death" RETIRED but still owned. Had a Malone stg 1 tune, 11mm pump, R520, GT15/17 hybrid and more
1997 Passat TDI wagon - Im not really sure why i bought this... anyone want a running donor car??? body is rough.
ketchupshirt88 is offline   Reply With Quote
Old September 18th, 2017, 20:01   #5
evguy1
You do have some good choices of transmissions with the adapters I have online.
I also just delivered the first Nissan 4 cylinder adapter.
The Toyota is still under revision but close.
evguy1 is offline   Reply With Quote
Old September 26th, 2017, 18:58   #6
superhl
Currently removing the 2002 beetle engine. Then I will remove Isuzu engine. Then I will be ready to rock. I will post picture of the transmission when removed. Hoping I can use it but if not I located a couple of T-5"s
Old September 28th, 2017, 17:02   #7
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Link says this is a `93 Isuzu 5 speed tranny,looks like the starter placement could be a problem.?????? Anyone?
edit: Well after comparing to a Toyota, it looks pretty close.
1.9ZOOK is online now   Reply With Quote
Old October 3rd, 2017, 15:30   #8
superhl
Default Both engines ready to remove
I disconnected both engines, wiring, motor mounts, etc. I labeled all the wiring on the TDI with masking tape. Also labeled any part that needs to be removed. I pulled the tyranny Saturday from the Isuzu pickup. I will remove both engines and order an adapter plate and send the computer off for reprogramming.
Old October 3rd, 2017, 15:47   #9
superhl
Default Isuzu tryanny
I was hoping maybe this is the same tranny as S10 T-5.
Old October 21st, 2017, 15:16   #10
superhl
Default rear seal
Removed engine from beetle and wondering if I should replace rear main seal and oil pan gasket? Engine has 130,000 miles. I sent my ECU to Whitbread to tune. Ordering my adapter from http://gastodiesel.tdconversions.com/ tomorrow once I pickup my transmission- Chevrolet S10 V6 4.3L GM NV3500 NV 3500 Transmission 5 Speed. Wiring removal almost complete.
Old October 22nd, 2017, 17:39   #11
superhl
Default S10 V6 Tranny
Pickup tranny today.... Ordering adapter. Can't wait to put it together.
Chevrolet S10 V6 4.3L GM NV3500 NV 3500 Transmission 5 Speed and 2002 VW beetle TDI
Old October 28th, 2017, 03:40   #12
superhl
Anyone out there no where I can get a Chevy 153 tooth internal balance 2 piece rear flywheel without breaking the bank? Randy from TDI conversions suggest a heavier flywheel. I can find 16 lbs flywheels but the 22 lbs flywheel are expensive.
Old October 28th, 2017, 21:00   #13
Motohead1
22 will not be enough. you need a 30lbs+ that RAM or Centerforce makes. its well worth the $200 price tag.
Dodge Dakota QC Tdi
Old October 29th, 2017, 13:42   #14
Exenos
TDI(s): 02 Golf
I found a stock 27lb flywheel used. With the larger diameter and extra mass it has over twice the ke of a stock tdi flywheel. I'm confident that that will be more than enough for my swap, i'd guess it'd be the same for you.
Your truck is nowhere near as heavy as motoheads Dakota so you wont need as large of a flywheel as he did unless you want it. I would put money on 22lbs being enough but a heavier flywheel does make for an easier drive.
Exenos is online now   Reply With Quote
Old November 7th, 2017, 15:19   #15
superhl
Default found 30 pound flywheel
Matt Whitbread sent me an ebay link for a 30 lb flywheel. It should arrive this weekend. Waiting on Matt to send me the adapter and my ecu tune job. I removed all the wiring from the beetle and it is in the middle of my living room. I have removed most the tape.
1992 Jetta TDI swap malone tune Thaines28 TDI Cars for Sale/Wanted 0 December 30th, 2015 10:51
swap TDI 1992 a 900$ Smog Quebec 0 July 6th, 2005 05:05
** FS : Jetta 1992 with 1998 TDI SWAP with mods ** GiGGer TDI Cars for Sale/Wanted 1 March 9th, 2005 22:45
Jetta 1992 avec Swap TDI 1998 a vendre GiGGer Quebec 1 March 1st, 2005 12:48
Jetta 1992 with TDI 98 complete Swap in Canada, QC GiGGer TDI Cars for Sale/Wanted 2 January 3rd, 2004 13:43
Page generated in 0.20616 seconds with 13 queries
[Output: 120.84 Kb. compressed to 100.02 Kb. by saving 20.83 Kb. (17.24%)]
