Old August 31st, 2017, 15:16   #1
Beastatpoi420
TDI(s): 00 nb 1.9
Default Evry modd toggle switch help
I can't find anywhere how to wire in a toggle switch, I don't have a pot n currently have a 2 prongg toggle and a resistor....im assuming one wire from toggle goes on the resistor n the other to a power source? I'm los5 do I nwe'd a pot to have it switched?
I know guys stupid post I apologize but I was running the mod consistent for a day or so n thrre were plenty of times where I didn't need it and I don't think baby footing the pedal is the solution while that is hooked up.
Beastatpoi420 is offline   Reply With Quote
Old August 31st, 2017, 16:03   #2
h4vok
h4vok's Avatar
Have you looked into getting a MPPS cable and making a tune yourself? Got the cable for $30 and then you need to find a working windows xp laptop. It is the proper way to do what the evry mod is doing just increasing fuel. Making a tune where all you are doing is increasing fuel is easy. Also you can make it so there is only increased fuel when over lets say 50% throttle so there is no turning it off and on its all in your right foot.
I know this does not answer your question, but I have considered the evry mod myself and ended up self tuning instead.
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is offline   Reply With Quote
Old August 31st, 2017, 17:20   #3
Beastatpoi420
TDI(s): 00 nb 1.9
That does sound like a good idea, but for the time being tho I just need to know how the toggle is wired, lol I have a light bar on my roof but still can't figure this toggle out haha
Old August 31st, 2017, 17:54   #4
Vince Waldon
Vince Waldon's Avatar
The switch goes in series with the resistor:
Pump ---> one side of switch ---> other side of switch ---> one side of resistor ---> other side of resistor ---> pump
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old August 31st, 2017, 18:14   #5
Beastatpoi420
TDI(s): 00 nb 1.9
So pump you mean pin 2 or 3 ...i just wire it in before the resistor n then on the resistor
Old August 31st, 2017, 20:50   #6
Vince Waldon
Yup... the resistor and switch form a loop between the two pins on the pump connector you are currently bridging with the resistor.
You're simply using the switch to put the resistor in or out of the circuit.
MFI Toggle switch is flakey TypeRod VW Passat Family (NMS and B7) TDIs (2012+) 2 November 28th, 2013 09:40
VW Fog Retro using Toggle Switch vs Light Switch stp1971 VW Passat Family (NMS and B7) TDIs (2012+) 43 September 25th, 2013 00:24
The Evry Mod + Toggle Switch = Smoke Mod (Pics, Vids, & Links) PhunkFX VW MKIV-A4 TDIs (VE and PD) 19 June 9th, 2013 16:23
Toggle switch for elevated idle slamhouse VW MKV-A5 Golf/Jettas 14 November 11th, 2012 18:16
GP Toggle Switch derheilige82 TDI 101 29 November 23rd, 2010 11:26
Page generated in 0.12235 seconds with 13 queries
[Output: 73.81 Kb. compressed to 64.61 Kb. by saving 9.20 Kb. (12.47%)]
