AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
This is a "partial" copy and paste from the Glow Plugs 101 ***Ver.201*** by Wingnut.
I'm getting 16764 / P0380 code
So, the car I am working on is a 2001 with the 2-wire harness which was replaced sometime prior to June 2013 when the guy purchased it (I did a TB job on it that month). The harness looks just fine... no cracking, the splice looks crimped really nice and had tape over it.
I pulled the harness and plugged in a known good GP....... grounded! Then, I cycled the GPs several times ........ no get hot, as in no smoke either.
So, is this a GP Relay issue? If so, where is that sucker located?
Or, is that "splice" the issue?
The glow plug codes are a popular code to be thrown on our cars. Several versions of the DTC are
16764 / P0380 code (Glow plug/heater circuit electrical fault (Q6))
17055 / P0671 code (Cylinder 1 Glow plug circuit (Q10))
17056 / P0672 code (Cylinder 2 Glow plug circuit (Q11))
17057 / P0673 code (Cylinder 3 Glow plug circuit (Q12))
17058 / P0674 code (Cylinder 4 Glow plug circuit (Q13))
The first code is for 2001 and older cars. They have a 2 wire glow plug harness, so just throw a generic code for the glow plugs.
The other codes are just examples of codes you might find on a 2002 or newer car. They have a 4 wire harness, so the ECM can specify the problem plug.But the trouble shooting procedure is the same for all three codes.
