Nero Morg
Hey all, I promised a few people that I'd share pictures of my HID setup that I got from Midwest Light Creations. I was shocked on how easy these were to install.
First of I started by removing the bumper. No pics there, figured there's plenty of DIY's out there for that.
Say goodbye old headlamps!
Next comes the new headlamp. As said in the listing it doesn't come with the 194 city bulb or the 7507 turn signal. Didn't think much of it at first, but then I found out that the turn signal sockets are completely different! Original socket on top, "new to me" socket from the new headlamps below:
I was also wondering where the heck the 194 bulb went, at first I didn't see the socket, but turns out it was just tucked into the housing. Bulb then in turns gets pressed into said hole.
New headlights installed! Bumper already put back on.
And the light cutoff is super sharp. I was amazed on how clear it was.
All this was literally plug and play. No splicing or cutting required. Eventually I'll run the signal wire for the fog lamps, but that's for another day. For now I get to yard the bumper back off and put some shims on the lower mounts to aim the lights up a teensy bit more.
