TJ__
Hello,
This morning on my way to school i unlocked my car with my remote as usual, started the car, and drove off. When I got to school, and was walking away from the car, the remote would not lock the doors. Trunk, lock, unlock, panic, nothing worked. So I went to lock the doors with the key, and they key would only go maybe half an inch into the door lock.
I was at the dealer just a little while ago and they said the battery is fine and think I need a new remote. I don't think that is entirely the case.
My car has been starting pretty crappy lately, seems I may need a new battery soon (lights very dim while starting, takes a while to actually start). I am wondering if starting the car had the voltage go too low and reset some sort of computer system in the car?
The key starts the car fine, and the key also works in the trunk just fine. I had my driver skey mechanism replaced a little while ago (windows would go up or down, sensor was broken as well). I tested the new module as soon as it was installed, maybe a month or two ago, and it worked fine. I have not used it since then.
It is also very cold outside here (Ottawa), so maybe the drivers door lock is frozen? Any help would be great!
TJ
TJ
