VLS_GUY
I went to to the new Audi dealership in Oxnard to look at the Q7 3.0 TDI. As kit turned out it was delivered with out its ad blue solution in the tank. It was putting out fault codes as a result. A young UTI graduate on his first job figured out the socket to use (17 mm) to open the ad blue cap. after the ad blue, a struggle with the VAS 1552 to reset (reboot) the MIL and I was set for a short test drive. This thing is smoother and quieter than any VR6 gas engine I have been around. It is no power house but delivery power is smooth-it reminds me of a well set up GM small black.
Once I got back to the dealer I went to the sevice manager to check up on cost of ownership. I wanted to know about the downside associated with having 4 timing chains.
Here is the parts cost and Labor Units for each part associated with a complete timing chain job:
Part Quantity; Cost; Labor Units; LU,Total
Timing Chain, 4; 120.00; 1.5; 6
Rail, 1; 142.00; 1.30; 1.30
Tensioner, 3; 126.00; 2.9; 8.70
Guide, 2; 56.00; 2.9; 5.80
Gilmer Belt, 1; 55.00; 2.70; 2.70
Water Pump, 1; 285.00; 1.9; 1.90
Total: Parts: $1,612.00; LU: 25.40
If each LU is worth $ 95.00 then the labor is worth around $ 2,300. Then add sales tax to the above amounts and you are well north of 4K for parts and labor.
The DSG transmission must be serviced at 35,000 mile intervals I was given no cost as the data base went down in the midst of doing this. The Gilmer belt is to be checked at 110,000 miles no replacement required but assume by then it will be worn and likely require replacement.
The service manager felt that if the chains and associated hardware need replacement then a design problem exists. She was previously a Mercedes service writer and is rather innocent about VOA warranty issues. Her car is a 1.8T Bug so she was all ears about VW issues and where to take her car in the local area.
Just some thoughts for those wanting a 3.0 TDI...
