Orders TDI Club Cards TDIFest 2015 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old April 19th, 2015, 11:16   #496
tdiatlast
arto_wa: nhdude's point is that your DPF didn't "fail" from its ash load, but probably from an internal failure/crack.
This is important to note, as the ash capacity (not exact!) of the DPF seems to be in the 200-250ml range before clogging requires a replacement. Your ash load, at 101k miles, was entirely normal.
You're correct, though, a failure is a failure. We just need to keep possible causes distinct.
2014 Passat TDI SEL DSG, White, Cornsilk, built 1/2014, purchased March 22, 2014
2009 JSW TDI DSG, Reflex Silver, Anthracite vinyl, built 11/2008, FrostHeater installed at 800miles purchased Jan 18, 2009
tdiatlast is offline   Reply With Quote
Old April 19th, 2015, 16:50   #497
Andy_2009_JSW
Default And the filling continues...
Member Name: Andy_2009_JSW
Model Year: 2009
Model: Jetta Sportwagen
Tranny: DSG
Miles: 136250
Oil Ash Volume:168 ml
Oil Type: Mobil-1 ESP 5w30
Avg MPG 35-ish
State: GA
Additional VCDS (version 14.10.2) data points:
8.7g Soot (calc)
0g Soot (meas)
2 Requested Regens
0 Successful Regens
8.4l Fuel consumption since last regen
120 km distance since last regen
144 time since last regen (minutes)
Remarks:
My P0401 (EGR insufficient flow) codes/check-engine light occurrences have gotten/are getting worse. CEL was on for 2+ weeks recently, cleared by itself the other morning, and then returned after a day or so. Current P0401 fault frequency is 81. I've cleared the codes and will continue to track. I've had soot on/at my tailpipe for 10's of thousands of miles, so I suspect a cracked DPF, which would be consistent with and explain why soot is filling up the EGR.
The Delete trigger may get pulled at some point...
Andy
2009 JSW TDi (09/08), Salsa Red, 17" Gray Goals, DSG, Curt trailer hitch, Dieselgeek Panzer plate, Aspherical mirrors, H&R RSB, warrantied mechatronic replacement (02/12), unwarrantied turbo failure (at 80K mi, 06/12), radiator replaced @115K mi (03/14), rear towing springs (03/15), ~136k miles so far
Andy_2009_JSW is offline   Reply With Quote
Old April 19th, 2015, 17:02   #498
Andy_2009_JSW
Originally Posted by arto_wa View Post
Well well, above is my post regarding DPF ash loading as of March 10, 2015
Late last week I got CEL and fault code at about 103,500 miles:
1 Fault Found:
001025 - EGR System
P0401 - 000 - Insufficent Air Flow - Intermittent MIL ON
It turned out that the DPF filter had failed, causing EGR system to plug up with soot.
According to the dealer, the DPF had to be replaced, which was done yesterday!
As it looks now, measuring ash volume with VCDS was pretty meaningless at least in this case!
New DPF was about $1,600 less 10% discount + labor.
Cheers
Ah, the benefits of a 2010+ model -- $1600 vs $5000 for fixing this issue!
I'd still encourage you to check the ash load and report it in this thread -- just note the miles since the DPF was replaced, I suppose, perhaps in addition to the vehicle mileage.
Andy
Old April 19th, 2015, 17:13   #499
Andy_2009_JSW
Originally Posted by PowerslavePA View Post
Member Name: (None, Coworker w/PowerslavePA)
Model Year: 2011
Model: Jetta TDi
Tranny: DSG
Miles: 261,389
Oil Ash Volume: 120 mL
Oil Type: All Dealer Serviced Oil Changes @ Scheduled Intervals
Avg MPG: 42.3
Comments: Still on the original timing belt
Wow, serious outlier in the ash load data trends, but in a good way. In a way that it should have been for everyone...
Dealer serviced oil changes, yet the timing belt (and coolant pump, and pulley tensioners/etc.) has not been changed? This does not compute. And is just plain against all common sense.
Andy
Old Yesterday, 05:54   #500
arto_wa
Fuel Economy: So far the best is 48 mpg on a smooth freeway trip at 70 mph!
I see what you mean about the benefits, but it's still hard to celebrate cracked DPF, especially after the labor and tax were added...
I will check and report the ash load next week - by then it will have at least 3,000 more miles on it.
No chance to do it sooner.
arto_wa is offline   Reply With Quote
Old Yesterday, 06:14   #501
kjclow
So it was just the DPF that cost $1600? What was the labor charge?
Old Yesterday, 06:30   #502
tdiatlast
Model Year: 2011
Model: Jetta TDi
Tranny: DSG
Miles: 261,389
Avg MPG: 42.3
This post makes no sense. "Dealer serviced" vehicle, and they DIDN'T insist on changing the timing belt, TWICE?
This makes me want to completely dismiss the Oil Ash Volume number, as well. Based on the many posts in this thread, I can't believe the number.
I respectfully request the poster reconfirm the info he has posted, as this thread is about real numbers, not (possibly) fabricated ones, especially since the poster isn't the owner of this car. If the numbers aren't accurate, the post should be removed from the thread.
Long-term DPF data project DoctorDawg VW MKV-A5 Golf/Jettas 55 January 30th, 2013 16:42
Off-topic posts from Cam Failure Data Collection thread donDavide Fuels & Lubricants 63 June 14th, 2011 23:18
PD cam failure - Data collection thread SBAtdijetta Fuels & Lubricants 116 February 25th, 2011 21:21
Biodiesel in DPF/Clean diesel vehicles Drivbiwire Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 6 August 25th, 2010 08:55
2009 Jetta Clean Diesel w DPF = Regen? Rod Bearing TDI (Diesel) Emissions 5 October 15th, 2008 18:58
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Copyright - TDIClub Online LTD - 2014
1996 - 2015, All Rights Reserved
Page generated in 0.11873 seconds with 12 queries
[Output: 87.25 Kb. compressed to 76.58 Kb. by saving 10.67 Kb. (12.23%)]
