Meefoo
Solved - 2015 jetta tdi airbag light
Hello. I just bought a rebuilt 2015 jetta tdi with only 29k miles! Unfortunately, the airbag light was a disclosed issue. The seller had installed a new airbag module with the same part number as the original, replaced the two front airbags, and the seatbelts. I jave evidence of the module and airbag replacement, but no written proof of the seatbelt replacement. He claimed that he did not have access to a ross-tech cable for coding, which was the reason why the light is still on.
I have a friend with an original cable, yet we have been unable to code the new module. We receive "coding rejected... error 22: conditions not correct or request sequence error"
I really need more help figuring this out... Other than the airbag light, the car seems to be operating perfectly.
Thanks everyone.
Below is an auto-scan log
Friday,30,November,2018,15:07:14:61175
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 47960km-29800mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 44 56 75 77
VIN: Mileage: 47960km-29800miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CVCA) Labels: None
Part No SW: 04L 997 016 E HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9465
Revision: 8AH20---
Coding: 011D0012042410085000
Shop #: WSC 09228 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016E 004002
ROD: EV_ECM20TDI01104L997016E.rod
VCID: 356B4F6B94AF81E236-8060
1 Fault Found:
4710 - No Communications with Airbag Control Module
U0151 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:25
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 64 °C
Intake air temperature: 52 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.460 V
Unlearning counter according OBD: 37
Limitation: accelerator pedal: 140.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 0
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4517
Revision: 05652104 Serial number: 00001406211619
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 254B9F2BEC0FF16286-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49220001851102ED921B0042A1100012
Shop #: WSC 00066 000 00000
VCID: 040DE2AF87F5E86AF1-8050
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 14:05:26
Freeze Frame:
Count: 0
Count: 14
Count: 16384
Count: 8226
Count: 44032
Count: 64000
Count: 254
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0355999628
Coding: 000F0F
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW36.rod
VCID: 377745638EA373F224-8062
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CG HW: 5C0 820 047 CG
Component: J301 Klimaanlage 0208
Revision: 2001001S Serial number: 00000002575534
Shop #: WSC 00066 790 00012
VCID: 67D7D5235683237274-8032
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78003039150353
Coding: 7B994B9A082B0F0008382080240884C50F86702E60000050B0A050022844
Shop #: WSC 18603 002 1048576
VCID: 30657E7F63CDA4CA65-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585141210204313
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584141216153129
Coding: 820000
Subsystem 3 - Part No: 5K0 959 591 A
Component: J245 PS41.402 H02 0003
Serial number: 0000FST00010IDW00000
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 0381505132100536AD1B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587141219154235
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14202586150106195715
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD08AG9T
Coding: 00000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72E1B477A541D6DAD3-8026
Seat occupied recognition:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029YKF0M
Coding: 303146
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME1B44584AZZZ/
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME4540584AZZZY
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME5C115133ZZZK
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME35085133ZZZI
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME2E4C6E31ZZZ7
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME44516E31ZZZX
7 Faults Found:
9442587 - Igniter for battery interrupt
B1015 1B [129] - Resistance Too High
MIL ON - Not Confirmed - Tested Since Memory Clear
9548571 - Ignitor for High Voltage Battery Interruptor
B11B3 1B [129] - Resistance Too High
9572123 - Ignitor for Passenger Airbag Release Valve
B120F 1B [129] - Resistance Too High
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [129] - Resistance Too High
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [129] - Resistance Too High
9437713 - Igniter for Passenger's Airbag
B1002 11 [129] - Short to Ground
10490624 - No End-of-Line Programming
B2013 00 [137] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 954 A HW: 5C6 920 954 A
Component: KOMBI H04 0807
Serial number: 00000000000000
Coding: 270A01
Shop #: WSC 00066 000 00118
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2C5D6A0F47E5C02A59-8078
1 Fault Found:
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 252
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:27
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70E5BE7FA34DE4CA25-8024
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 252
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 14:05:25
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0807
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1AC178D911E1A6B-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000008901003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30657E7F6BCDA4CA65-8064
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3973435B70B76582D2-806C
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H
Component: Radio Prem-8 H08 0009
Revision: -----13S Serial number: VWZ4Z7R3668074
Coding: 01000440020006
VCID: 2D5B670B74FFC9224E-8078
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 212
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 13:13:09
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140534
Coding: 02630102C21632007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 142DD2EFFF9578EA61-8040
1 Fault Found:
0035 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:32
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666938201
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 3261747765C196DA13-8066
End-------------------------(Elapsed Time: 03:31)--------------------------
Thanks everyone.
www.Ross-Tech.com
VIN: License Plate:
Revision: 8AH20---
1 Fault Found:
U0151 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:25
Coding: 0000020
Revision: 00H46001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 14:05:26
Freeze Frame:
Count: 0
Count: 14
Count: 16384
Count: 8226
Count: 44032
Count: 64000
Count: 254
Count: 0
Coding: 000F0F
Coding: 820000
Coding: 820000
Coding: 180000
Coding: 280000
Coding: 800000
Coding: 800000
Coding: 00000000
Coding: 303146
7 Faults Found:
B2013 00 [137] - -
Coding: 270A01
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 252
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:27
Revision: B8078001
Coding: 102200
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 252
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 14:05:25
Serial number:
Coding: 000007
Cannot be reached
Revision: 00H22000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 212
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 13:13:09
1 Fault Found:
0035 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:32
ROD: EV_UHVUMI.rod
