2015 jetta tdi airbag light
Meefoo
Philadelphia, pennsylvania
2015 Jetta SE, 2009 Bora, 1999 Jetta
Solved - 2015 jetta tdi airbag light
Hello. I just bought a rebuilt 2015 jetta tdi with only 29k miles! Unfortunately, the airbag light was a disclosed issue. The seller had installed a new airbag module with the same part number as the original, replaced the two front airbags, and the seatbelts. I jave evidence of the module and airbag replacement, but no written proof of the seatbelt replacement. He claimed that he did not have access to a ross-tech cable for coding, which was the reason why the light is still on.
I have a friend with an original cable, yet we have been unable to code the new module. We receive "coding rejected... error 22: conditions not correct or request sequence error"
I really need more help figuring this out... Other than the airbag light, the car seems to be operating perfectly.
Thanks everyone.
Below is an auto-scan log
Friday,30,November,2018,15:07:14:61175
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 47960km-29800mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 44 56 75 77
VIN: Mileage: 47960km-29800miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-CVCA) Labels: None
Part No SW: 04L 997 016 E HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9465
Revision: 8AH20---
Coding: 011D0012042410085000
Shop #: WSC 09228 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016E 004002
ROD: EV_ECM20TDI01104L997016E.rod
VCID: 356B4F6B94AF81E236-8060
1 Fault Found:
4710 - No Communications with Airbag Control Module
U0151 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:25
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 64 °C
Intake air temperature: 52 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.460 V
Unlearning counter according OBD: 37
Limitation: accelerator pedal: 140.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 0
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4517
Revision: 05652104 Serial number: 00001406211619
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 254B9F2BEC0FF16286-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49220001851102ED921B0042A1100012
Shop #: WSC 00066 000 00000
VCID: 040DE2AF87F5E86AF1-8050
1 Fault Found:
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 14:05:26
Freeze Frame:
Count: 0
Count: 14
Count: 16384
Count: 8226
Count: 44032
Count: 64000
Count: 254
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0355999628
Coding: 000F0F
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW36.rod
VCID: 377745638EA373F224-8062
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CG HW: 5C0 820 047 CG
Component: J301 Klimaanlage 0208
Revision: 2001001S Serial number: 00000002575534
Shop #: WSC 00066 790 00012
VCID: 67D7D5235683237274-8032
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78003039150353
Coding: 7B994B9A082B0F0008382080240884C50F86702E60000050B0A050022844
Shop #: WSC 18603 002 1048576
VCID: 30657E7F63CDA4CA65-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585141210204313
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584141216153129
Coding: 820000
Subsystem 3 - Part No: 5K0 959 591 A
Component: J245 PS41.402 H02 0003
Serial number: 0000FST00010IDW00000
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 0381505132100536AD1B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587141219154235
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14202586150106195715
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD08AG9T
Coding: 00000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72E1B477A541D6DAD3-8026
Seat occupied recognition:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029YKF0M
Coding: 303146
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME1B44584AZZZ/
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME4540584AZZZY
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME5C115133ZZZK
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME35085133ZZZI
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME2E4C6E31ZZZ7
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME44516E31ZZZX
7 Faults Found:
9442587 - Igniter for battery interrupt
B1015 1B [129] - Resistance Too High
MIL ON - Not Confirmed - Tested Since Memory Clear
9548571 - Ignitor for High Voltage Battery Interruptor
B11B3 1B [129] - Resistance Too High
9572123 - Ignitor for Passenger Airbag Release Valve
B120F 1B [129] - Resistance Too High
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [129] - Resistance Too High
9441051 - Front passenger's safety belt tensioner igniter 2
B100F 1B [129] - Resistance Too High
9437713 - Igniter for Passenger's Airbag
B1002 11 [129] - Short to Ground
10490624 - No End-of-Line Programming
B2013 00 [137] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 954 A HW: 5C6 920 954 A
Component: KOMBI H04 0807
Serial number: 00000000000000
Coding: 270A01
Shop #: WSC 00066 000 00118
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2C5D6A0F47E5C02A59-8078
1 Fault Found:
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 252
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:27
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70E5BE7FA34DE4CA25-8024
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 252
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 14:05:25
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0807
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1AC178D911E1A6B-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000008901003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30657E7F6BCDA4CA65-8064
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3973435B70B76582D2-806C
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H
Component: Radio Prem-8 H08 0009
Revision: -----13S Serial number: VWZ4Z7R3668074
Coding: 01000440020006
VCID: 2D5B670B74FFC9224E-8078
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 212
Mileage: 47933 km
Time Indication: 0
Date: 2018.11.24
Time: 13:13:09
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140534
Coding: 02630102C21632007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 142DD2EFFF9578EA61-8040
1 Fault Found:
0035 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 47933 km
Date: 2018.11.24
Time: 14:05:32
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666938201
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 3261747765C196DA13-8066
End-------------------------(Elapsed Time: 03:31)--------------------------
D-Cup
San Antonio TX
2010 Jetta TDI Cup Edition, 2003 Jetta GLS, 2000 Jetta GLS, 2012 JSW
Just by coincidence, I received mail from VWOA informing me of a recall affecting 2010-2018 models where the airbag light comes on. Recall is due to failure or malfunction of a spiral wound cable or spring thingy that keeps the airbag powered while the steering wheel moves. Apparently it can get dirty enough with hair/dust/debris to make that light come on.
Warranty for this item is extended through 10yrs or 120k miles (I think) from original inservice date of vehicle.
Not sure if this would apply to your rebuilt auto, but doesn’t hurt to ask.
Dubin20th
Illinois
2015 Jetta
Probably have to take the car to the dealer to code and activate the new module. Aside from coding, the airbag module is normally in a protection mode when replaced.
Meefoo
Thanks for the ideas... Ultimately I succeeded in fixing all of the problems!
My primary problem was a faulty main airbag module. Replacing it again cleared all but 1 of my faults. The remaining fault was the "short to ground" at the passenger airbag.
My "short to ground" was caused by faulty connectors at the passenger airbag. I opened a connector and is appears to be a fusible link, so my assumption is that the connector is designed to fail after airbag deployment. Prehaps as a safety against amateur airbag installation? Just speculating. I had to cut off the old connectors and attach new ones (technically used connectors from a salvage yard, that came from a vehicle with a non-deployed passenger airbag). I used electrical solder to ensure a strong connection at the splices.
I hope this post helps someone else.
