TDIMeister
Phd of TDIClub Enthusiast, Moderator at Large
The 3.0 V6 TDI would be would be your best bet because it was/is sold here. Scott DeWit had a couple of 2.5 5-cylinder CR-TDI long blocks from the VW Crafter brought in - I don't know whether these include the complete FIE, ECU and harnesses or not. Ask him about that.
The older VE-pump 5-cylinders can also work, retaining the electronic control of the pump or mechanizing it; there's no real magic or mystery with them if one already know the 4-cylinder counterparts.
Alternatively, you can import a 2.5 V6 TDI and ostensibly convert the VP44 pump to a mechanical one to make the swap simpler and control the VNT with this: http://dmn.kuulalaakeri.org/vnt-lda/
Most of the challenges will lie in making the VAG ECU talk with the non-VAG chassis (and transmission) in your F150. The fabrication and fitment will be relatively trivial in comparison.
