Houpty GT
Lug nuts work too
-You only need mk4 N75 if you are running a VNT turbo and tune.Holy wow, first time I've been on here on a PC in a while, sorry about that giant picture - fixed.
Thundershorts, between the bad cam and the oil pump, I would fathom a guess the that engine has seen some oil starvation. So my next thought is that they're not great. I'm going to cross my fingers that nothing catastrophic happens, run this and rebuild the engine that I have sitting in the garage.
My GF had company for the past two weeks which made it hard to spend time in the garage without being impolite. I got some time in there tonight and hope to have the car back on all four tomorrow and getting fluids in it.
I have my tune from VWMIKEL on hand and I just installed the chips in the ECU. Two stupid questions that I can't seem to find the answers to:
1) Do I need an MK4 N75 to run an MK4 MAP sensor? (I'm thinking no)
2) The MK4 MAP sensor goes as close to the intake as possible on the "cold" side, correct?
Ah, makes sense about the VNT.-You only need mk4 N75 if you are running a VNT turbo and tune.
-MAP sensor gets installed in boost pipe before intake manifold or in intercooler itself, some have mounted it to the intake manifold..
I do have a corrado dual fan u could haveAh, makes sense about the VNT.
I'll work it into the piping for the time being I think.
Got the CVs hooked back up today and the car is on all fours. I hate doing CV joints, always have. I'm putting the engine compartment back together and got side tracked thinking about how giant the single G60 radiator fan is. I went over to my storage and snagged the double Mk3 fan - its about 2" too short for the G60 Radiator length wise and 2" too tall, so I trimmed the bottom to the base of where the fans hook in and made adapters to extend it. I took some rust off the edges and painted it up, so that will be ready to go in in the morning as I get the other plumbing going.
did I mention the price? $0.00 for TDI club membersThanks for the offer. I'll have to see how this one handles the but the mounting seems pretty solid.
You were going to throw away classic vw parts??? Don't let Pod hear you say that!I just threw the frame from a corrado / ecodiesel dual fan into the trash... the motor was bad and the bearing on the "slave" fan was bad too. Should I save it?
-J
Not doubting your skills..trying to unload some dust collecting clutter!Something is starting to make me thing you all doubt my fabrication abilities with my retrofitted mk3 fan The change was a spur of the moment thing....
What I really need is a pipe bender... I'm having a hell of a time with my inter cooler piping!
