BakoTDI
Have you considered installing a Fumoto drain valve? you can make your own drain hose with a 90 and you won't have any messes.Only complaint I have is that you still have to remove the whole skid plate to change the oil, even if you order the one with the hole cut out to access the oil drain plug.
