njt1rider
Does anyone have a diagram of what number each wire is on the T24 connector? There are numbers stamped for the outside wires but it seems all the wires within the outside circle are a mystery...I found #13...looking for #12 and #19. I'm pretty sure I can tell by the color but just want to be certain ya know?
EDIT: I found what I was looking for; traced the wire back to the ECU using the schematics to verify.
Turned out we wired the ALH pump swap incorrectly. You are supposed to wire the connector going from the T24 plug bolted to the coolant flange to the thee wire connector going to the AHU IP pump. I didn't like that because then the engine harness isn't in 2 pieces like it was designed. So I found where the wires connect to T24 on the ECU side of the harness, de-pinned, and re-pinned them to the T10 ALH IP plug.
They're old home (I included the numbers in case anyone needs this info in the future)
They're new home:
They're new home:
