Luvbug
Thank you, excellant pics and instruction, one happy Brit, just have to change the battery in the keyfob now?
The problem on the Beetle (which seems like it could occur with any model) was that the switch disk was stuck on the shaft of the fan control knob. When I pulled the knob out the disk came with it. In the process of pulling the wiper came out from under the contacts in the body of the switch (without bending or breaking, my lucky day). To fix it I needed to pull the central dash apart and then disassemble the heater control module (by pulling out all three knobs and then releasing the clips around the black part to allow me to separate it from the body). Once had it apart I was able to remove the disk from the shaft of the fan control knob and then put the disk back in place with the wiper underneath the copper arc shaped piece on the left hand side and snap it into the clip on the top. Worked fine after I put it all back together.dlu said:I tried this on a 1998 New Beetle and was not able to get the switch out (it pulled out about an inch, but would not come the rest of the way) and the fan no longer comes on.
Worked like a charm on the 2002 Jetta wagon.
This the correct dealer part number?Wingnut said:I am not 100% sure about this, but I think the part # for the bulb is N 017 751 2. Maybe someone can confirm this for me?
Yes, it is. The filament is broken, due to thinning out from the normal use, it boils away slowly and that is the blackening you see on the bulb globe.SheeB said:My hvac illumination just died last night, but if I tap either side of the dash surrounding the hvac control the illumination will return for a short period of time. This an indication of a bad bulb? All the hvac control work fine.
Ditto! Thanks Wingnut!just another chime in that this is such a great site, and it's people like wingnut who make it happen.
in the space of an hour i sat down and searched the forums, found this thread, went to autozone and installed a new lamp. now i'm off to the next task.
thanks!
