lucassayers7
- Joined
- Oct 22, 2017
- Location
- southern NH
- TDI
- MK6 TDI Golf (recall) MK1 Rabbit TD from NA(sold) MK1 Scirocco TDI (Building)1990 Corrado TDI(Daily)
Hello all For a couple of weeks my AHU corrado has been breaking down more and more on the highway ill be driving along and then i will lose power and it will start dying and throwing blue smoke out the back and goes back and froth on coming back to life sometimes it goes to slow and i pull over and let it idle for a while if i stop it its really hard to start back up.2nd thing it also feels like it will go into limp mode on the highway all of a sudden it wont go anywhere fast but the way it does this is by making the first bit of my pedal responsive and the rest dead even more than the normal amount i have that is dead. Every time i start the car and pull away it hits 1200 rpms stays there no matter if its on the floor and waits till i lift up and then hit the pedal again then its back to normal. and i was noticing once i hit 60% of my pedal the rest keeps it the same(acceleration, noise, everything) using an obd2 to scan the throttle responsive it goes up to 100 but from 60 to 100 nothing changes. sorry for the long post but a lot is going on.
