todo
I have a 2005 Passat B5.5 TDI wagon with 140,000 miles that starts readily and idles at 650rpm. When I step on the gas pedal NOTHING happens- as if the gas pedal were not connected. On VCDS the throttle is detected and shows the full range from 0-100%. On Autoscan there are no codes except those indicating that the TCM is missing.
I acquired the car in September and the engine started and ran perfectly. The automatic transmission was toast and so I started down the road of swapping in a manual transmission (FHN). BTW many thanks to all of you in this forum who shared their experience and knowledge. I also decided to do the timing belt and BSM delete and so decided to do the tranny swap by pulling the engine and tranny out together. While I had the engine out I also replaced the tandem pump gasket and the coolant manifold and coolant temp sensor. All went smoothly until I tried to start the car.
This is where it gets a little complicated and I'm not sure this is even relevant to my current problem but at this point I won't make any assumptions. I contacted a Malone dealer here in California to flash my ECU for the manual trans and a Stage 2 tune. Long story short he screwed it up and the ECU was completely unresponsive. I sent it back to Malone who took full responsibility for their dealer's screw-up; they re-flashed my ECU, but it was still unresponsive. So I buy another ECU from a wrecking yard, send it to Malone, which they re-flash and delete the immobilizer. So now car starts (for the first time) but idles for a few seconds and then turns off. Immobilizer issue? So I take the ECU to a different Malone dealer here in the Bay Area and they delete the immobilizer delete (ie immobilizer is now activated) which results in the car not starting at all and VCDS showing many codes indicating multiple modules failing to communicate with the ECU- almost identical to the very first time I tried to start the car. So last week I sent both ECUs back to Malone and they flashed both ECUs with their original files (stock tune/automatic transmission) and now the car starts, idles, But has zero throttle response.
I have checked all fuses multiple times. I also replaced the 219 main relay and crankshaft position sensor with new OEM parts (part of the process when car wouldn't start at all). ECU, glow plug, and immobilizer dash lamps light up when turning the key on but are off when car is idling.
Frankly, I'm a more than a tad frustrated and would greatly appreciate any and all input from this forum.
Here's my most recent Autoscan:
Thursday,01,December,2016,10:28:39:45368
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WVWCE63B95E126365 License Plate:
Mileage: 225040km-139833mi Repair Order: 12/1/16
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWCE63B95E126365 Mileage: 225040km-139833miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 N HW: 028 101 198 2
Component: R4 2,0L EDC G000AG 1388
Revision: 12345678 Serial number: VWZ7Z0D1256844
Coding: 0150034
Shop #: WSC 06526 444 84896
VCID: 2952F06083481A0ACB-513C
1 Fault Found:
18034 - Powertrain Data Bus
P1626 - 000 - Missing Message from TCU
Freeze Frame:
RPM: 0 /min
Torque: 214.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00001000
Bin. Bits: 00000000
Bin. Bits: 10000100
Readiness: 1 1 1 0 1
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 05311
VCID: 254AFC50BF503E6AEF-513C
3 Faults Found:
P1626 - 35-00 - Missing Message from TCU
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 35-00 -
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 244CE154B46AC762F8-5120
No fault code found.
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F661E78EDAC743A15-515A
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 15235
Shop #: WSC 00000
VCID: 2756F658C55C2C7ADD-5120
WVWCE63B95E126365 VWZ7Z0D1256844
1 Fault Found:
01315 - Transmission Control Module
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05311
VCID: 70E4DD0430122BC24C-5120
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 80 Komfortger·t HLO 0004
Coding: 00258
Shop #: WSC 05311
VCID: 3776261815FCBCFA4D-4B18
Subsystem 1 - Part No: 1C1959801
Component: 80 Tırsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 80 Tırsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 80 Tırsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 80 Tırsteuer.HR KLO 0202
End-------------------------(Elapsed Time: 05:12)--------------------------
www.Ross-Tech.com
Coding: 0150034
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 214.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00001000
Bin. Bits: 00000000
Bin. Bits: 10000100
Coding: 04255
Shop #: WSC 05311
3 Faults Found:
P1647 - 35-00 -
Coding: 12345
Shop #: WSC 05311
Coding: 00118
Shop #: WSC 05311
Coding: 15235
Shop #: WSC 00000
1 Fault Found:
Coding: 00006
Shop #: WSC 05311
1 Fault Found:
Coding: 00258
Shop #: WSC 05311
