danthemanohhyea
Hello everyone.
Questions up front:
Details:
I deleted the balance shaft on my B5.5 Passat TDI. Of course along with that I changed the water pump and thermostat.
The car now exhibits intermittent poor to no heat in the cabin while driving.
Things I have checked:
I have not ruled out the possibility that the car is just not warming up completely.
It was ~45F this morning, but after ~10 miles highway driving it should have been pumping out some heat. Instead I had "mildly luke warm" air that quickly went cold after idling for a short time.
I have not logged the actual coolant temperature with Vag-Com yet, as this just started happening in the last couple days as I have just recently finished the engine work.
Since noticing this situation, both my wife and I have heard what sounds like a "scratching" sound under the dash. My wife insists something is under there , but I believe it may just be air purging through the system?
Questions up front:
- What's the best way to purge air from the coolant system?
- Does anyone have any other ideas on what could be happening?
Details:
- Coolant level is at MIN mark on coolant overflow tank
- Top radiator hose does get uncomfortably hot after highway driving, but not painfully hot.
- Flow control lever in HVAC system (under dash) is moving when I turn the temperature knob in the cabin.
- Coolant temp gauge moves normally to middle while driving. Never "overheats"
