Hi,
I have a Passat TDI 1.9 110HP 1999, with 230000Km.(I'm in France)
I have a lack of power since I bought it, limb mode, no power...you name it.
so I started by changing and cleaning parts:
new turbo.
EGR blocked.
All vaccum pipes changed to silicone.
New MAF (pierburg)
MAP checked working, cleaned and put back on.
N75 tested working.
injectors cleaned
new fuel filter.
when I drive on a level area, it goes ok, up to 2000rpm it doesnt pull, its like the turbo is not engaged, allthough I hear it hissing, then above 2000rpm it runs like it should, perfect power(above 2000rpm, not under).
now in up hill, I cant get any power, from 110-120 km/h, slows down to 60km/h, push the pedal to the flor, nothing, and this is not corrected by turning off the engine and back on, no it's all the time like this.
Can someone give me some help, may be there is something I didnt check or replaced...!!
Thank you.
new turbo.
EGR blocked.
New MAF (pierburg)
N75 tested working.
injectors cleaned
new fuel filter.
Thank you.
