Old September 24th, 2015, 14:32   #721
gothicreader
gothicreader's Avatar
Fuel Economy: City 43MPG HWY 45-46MPG
I've enabled the rain sensor, awhile back, but yet to test the other feature with the sunroof, etch. All in all the rain sensor works pretty well - sometimes too good.
I did make some mods in adding features like the seat belt chime, showing the console in both metric and miles, among other stuff. Works like a charm.
gothicreader is offline   Reply With Quote
Old September 24th, 2015, 14:45   #722
shak911
auto wipers is priceless..yeah sometimes it does a single sweep when it is not raining..could be due to direct sunlight reflection or whatever..
but for the auto close...it does not always work, sometimes no windows close..or only the front windows do...but really it is a none issue to me as I do not plan on leaving windows down or sunroof open...makes no sense..too risky
cheers
shak911 is offline   Reply With Quote
Old September 24th, 2015, 16:17   #723
o_a_ravi
Both auto rain wipers and sunroof/window closing works off of the RLS Rain Sensors. As others mentioned, its always a hit or miss thing., has to some something with the Sensor itself.
One thing i noticed was, ever since i replaced my windshields (stock windshield broked) replaced with a OEM equivalent one, which doesnt have the light green tint as the original glass.
Replacement Glass seems to work better with the RLS., the sensing is more responsive and works better now.
Thinking that there should be a VCDS setting to adjust the sensor threshold.
o_a_ravi is offline   Reply With Quote
Old September 24th, 2015, 17:16   #724
atc98002
atc98002's Avatar
I've seen a picture somewhere showing EGT in the MFD. Can that be enabled, or is additional hardware required? Would be a nice way to watch for a DPF purge. I can't use Torque, because I don't have an Android phone, and not going to get one just for that.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan: other daughter has 3 kids
atc98002 is offline   Reply With Quote
Old September 24th, 2015, 19:47   #725
pedorro
pedorro's Avatar
Additional device - the AutoPolar FIS+
The main thread is pretty easily located.
pedorro is offline   Reply With Quote
Old September 25th, 2015, 05:22   #726
atc98002
atc98002's Avatar
I was aware of that one. Wasn't sure if that was the only way. Thanks!
2005 Ram 1500
Old December 10th, 2015, 15:18   #727
Bobmws
Sold my Passat, have a Ross-Tech Micro-CAN cable for sale $150 shipped CONUS.
Email: bobmws4@gmail.com
Bobmws is offline   Reply With Quote
Old December 23rd, 2015, 14:22   #728
HighVoltageTDI
HighVoltageTDI's Avatar
I just picked up a Passat SEL and read that there is no way to keep the car running with the remote start which sucks. Is there any way to extend the run time. 10 minutes is a joke.
HighVoltageTDI is offline   Reply With Quote
Old December 23rd, 2015, 15:54   #729
Fav40
Fav40's Avatar
I too have an SEL and never wished for extended run time, but simply the ability to unlock once started. Idling these motors is just wear and tear, plus probably going add to the clogging up your DPF filter.
Installed a Frost heater @ 500 miles and I've been happy every time I get in my car on a cold day after plugging in.
http://www.frostheater.com/
Fav40 is offline   Reply With Quote
Old December 23rd, 2015, 17:14   #730
HighVoltageTDI
I will most likely pick up a frostheater for my 10' jetta and my new Passat, I wanted longer run times for when I cant plug it in. It would be nice to have the temp gauge move some when I get in it after working a 16hr day in the cold.
Old December 24th, 2015, 04:28   #731
deAutoLED.com
Originally Posted by JdC Machine View Post
I fiddled around with mine last night and left the bit for "DRL via separate bulb active" checked for gits and shiggles. I think it looks kinda cool to have the fogs and DRLs on together. Makes me question whether I should put the DeAutoKey LED DRLs back in or not. Having a "cool white" DRL with a slightly yellow-ish fog light might look odd.
I'm sure it's easy to picture in your head but I'll take a picture before I leave work tonight.
people normally install our white Fog LEDs which match the DRLs:
http://deautokey.com/product/passat-...-fog-light-kit
Thank you
LEDs - Vinyls - Keys
www.deAutoKey.com
www.Facebook.com/deAutoKey -- Like us for a chance to win prizes!
deAutoLED.com is offline   Reply With Quote
Old December 27th, 2015, 19:01   #732
HighVoltageTDI
So is there anyway to extend run time with VCDS when using the remote start.
Old December 28th, 2015, 12:34   #733
BigJimmy428
Not as of yet.
BigJimmy428 is offline   Reply With Quote
Old February 10th, 2016, 22:13   #734
Vagfan
Fuel Economy: 14km/l
I have a passat b7 2.0tdi bluemotion 170bhp MY2011 Comfortline in India.. The problem is i'm not able to activate Horn confirmation on lock/unlock even after enabling if from VCDS 15.7,Activate/Deactivate Blinking Confirmation works without issue. Also Staging/indicator celebration does not work it says Error:Channel Not available.Although many of my friends in India have activated these features on their passat, Jetta and Polo but i dont understand why i can't enable them in my Car.
Can anyone help please..
Vagfan is offline   Reply With Quote
Old March 31st, 2016, 10:16   #735
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Has anyone figured out how to enable the flashing CHMSL?
I see the 14's (or maybe the 15's) has the function enabled that will flash the CHMSL when you apply the brakes. I can't figure it out on my 13....
Fixmy59bug is offline   Reply With Quote
Black Grille on Passat NMS passatti VW Passat Family (NMS and B7) TDIs (2012+) 18 April 8th, 2013 08:09
What is the Passat NMS engine??? TDI2000Zim TDI 101 5 October 12th, 2012 16:55
You know you love your 2012 NMS Passat TDI when... Niner VW Passat Family (NMS and B7) TDIs (2012+) 39 May 29th, 2012 07:35
VCDS tricks? physicshogon OBD Scanners 8 October 20th, 2011 21:56
Page generated in 0.17925 seconds with 12 queries
[Output: 129.99 Kb. compressed to 108.83 Kb. by saving 21.15 Kb. (16.27%)]
