Old June 10th, 2015, 12:09   #706
Lightflyer1
Lightflyer1's Avatar
Early on there was discussion that was the reason it wasn't enabled to begin with.
Old June 10th, 2015, 15:40   #707
tadawson
Yeah, and they all read like pure BS, since the exact same stuff works fine in other countries. I think the bottom line is simply that US marketing didn't want the feature in this tier car, so chose interval instead, since it's one or the other . . .
- Tim
tadawson is online now   Reply With Quote
Old June 11th, 2015, 05:28   #708
Lightflyer1
You are entitled to your opinion as well. Not everyone has had flawless performance from their rain sensing window feature, like you seem to have.
Old June 11th, 2015, 08:01   #709
IXLR8
I have had issues with my rain sensor not working to drive the wipers. Needed to turn off wipers and the car to 'reset' system before they would work properly again. Others here have reported same issue. I also activated the closing window feature tied to the rain sensor. I left all 4 windows open about 1 inch, usually the windows close in the rain... but one time I came out to find that the front windows were closed and the rear windows were full open!! VW version in the NMS is not ready for prime time even though others seem to work without an issue.
Jim Peck
'12 TDI Passat SE 6M, Platinum Gray w/Moonrock- 86,750 miles, 52 mpg. Buyback 12/16/16
'02 TDI Golf, 5 spd., 290K miles -PP520, RC3+ , VNT-17, Webasto, .68 5th gear.
IXLR8 is offline   Reply With Quote
Old June 11th, 2015, 17:09   #710
mattfrayage
mattfrayage's Avatar
Seems to good to be true, but take a look at this
https://www.flickr.com/photos/818515...posted-public/
seems to be the engine acceleration speed governor NOW set to 300KPH
LOAD"*",8,1
when all else fails, Blame North Korea, for they are ALWAYS up to no good
my VW vids:http://www.youtube.com/playlist?list...lYQboyuttrsJ5e
mattfrayage is offline   Reply With Quote
Old July 15th, 2015, 20:00   #711
Jbratstdi
Fuel Economy: 43.5 Avg
On 12 model if you try to change to higher than 300 it says out of range.
Maybe on 13 and above it would work, that would put the tune company's out of biz. ... lol
Jbratstdi is offline   Reply With Quote
Old August 18th, 2015, 22:21   #712
Drnknmnky13
Anyone having issues with the rain auto close feature? My rain sensing wipers work just fine. But The rain auto close does not. I've poured water directly on the sensor and nothing happens. Car off and locked with fob.
EDIT: I think I figured out what was happening. I was being too impatient. If I pour water on it right after locking it would not work. However if I wait a little bit (like for the dash panel to go dark) it works every time. Maybe there is a timer or something? I dunno. But it's working now.
Thanks to all the gurus out there that have made these tweaks possible. Did a few of them today.
Drnknmnky13 is offline   Reply With Quote
Old August 21st, 2015, 04:37   #713
TDISEL
TDISEL's Avatar
The auto close feature didn't work reliably for me. That said, having auto wipers is, for the most part, great. Sometimes this gets a little weird too. Probably why the feature is not enabled.
It's really a TDI SE Sunroof.
TDISEL is offline   Reply With Quote
Old August 21st, 2015, 07:33   #714
Lightflyer1
Mine has been a bit wonky at times but overall I am happy with it being enabled. The auto close feature has saved me a few times and I like the auto wipers, when they work (most of the time).
Old August 25th, 2015, 20:04   #715
Night Blue 15 Passat
Night Blue 15 Passat's Avatar
So, with the introduction of electric power steering assist, has anyone found a VCSD coding to enable driver adjustable power steering assist in the 2015 NMS Passat?
Night Blue 15 Passat is offline   Reply With Quote
Old August 30th, 2015, 20:24   #716
jrm
Fuel Economy: 42/52
I did read somewhere where you can easily change the power assist levels
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old September 15th, 2015, 20:14   #717
Diesel 05/14
Compu_85-Do have cornering lights on your car?
Diesel 05/14 is offline   Reply With Quote
Old September 17th, 2015, 22:02   #718
Jbratstdi
You can also adjust brake power also I did it to my 21 tdi but don't remember how.... sorry but if you go into the abs setting or the brake settings I think you will be able to find it
Old September 18th, 2015, 06:25   #719
sleek98
Turned on the rain sensing wipers and rain close as well as turning off the DRL's. The sunroof only shut half way but the windows worked. Just have to tell the wife to keep the sunroof shut.
Rained all the way to work today and it was nice having the wipers adjust speed for how hard it rained.
Now just need to get a couple full tanks hand calced so I can adjust the screen readout to be correct.
2013 Passat TDI (Auto)
sleek98 is offline   Reply With Quote
Old September 18th, 2015, 10:04   #720
14tdipassat
I've searched unsuccessfully... anyone done this?
14tdipassat is offline   Reply With Quote
Black Grille on Passat NMS passatti VW Passat Family (NMS and B7) TDIs (2012+) 18 April 8th, 2013 08:09
What is the Passat NMS engine??? TDI2000Zim TDI 101 5 October 12th, 2012 16:55
You know you love your 2012 NMS Passat TDI when... Niner VW Passat Family (NMS and B7) TDIs (2012+) 39 May 29th, 2012 07:35
VCDS tricks? physicshogon OBD Scanners 8 October 20th, 2011 21:56
Page generated in 0.18310 seconds with 12 queries
[Output: 128.24 Kb. compressed to 106.89 Kb. by saving 21.34 Kb. (16.64%)]
