Hey Matt - that HVAC tweak is cool or hot, depending on your perspective. It changes the temperature range from 64-80 to 60-87 before clicking over to LO or HI. I also saw the other bit in Byte 3 (IIRC) for rear console controls. Well, I checked that one and it 'seems' to deliver more air to my retro-fitted rear AC vents.
Here is one thing I changed that has a COOL/HOT function
also the climatronics can also have staging via an adaption channel!
I also made a video to compare the sync of the instruments and climatronic display:
http://www.youtube.com/watch?v=EIx0tUmfR4I
EDIT: after testing it byte 1 bit 3 actually increases the amount of degrees the car can show- perhaps for high or low temperature climates?maybe canadian or saudi NMS's have this active?
either way it is easy and to some an improvement!
here is one i stumbled upon that appears to work:
Adaptation in the Instruments module (17) - Volume to be replenished -change from NO to YES
not really useful all that much...
perhaps it is for those automated hi-speed gas preset volume pumps like they have in some Russian gas stations?
EDIT: more stuff coming soon- at 15 degrees it is REALLY cold outside to be messing around!
Now for the really interesting part:
Since you have a '13, I assume that you have the 705 Kombi variant with the staging tweak and not the plain jane 507 Kombi that I have that does not allow that. Well the 507 also does not allow the Volume to be replenished either tweak. It shows as 'not available' in my cluster.
So while I was in there, and still not experiencing any joy with the oil temperature reading, I tweaked a few of the other ESI and SIE parameters and now I got this neat red oil can flashing at me whenever the engine is running, but not when the car is turned on (engine not running). It turns on for about 5 seconds and is off for about the same and repeats. The MFI screen is otherwise blank.
So while I think the oil level sensor is working for level, I quickly turned off the car, let it settle a few minutes and checked to see that the oil level was good, which it was. I was a bit concerned since I suctioned about 3 ounces of oil out for a mid-life UOA yesterday since my last one (and first UOA) indicated some higher than normal metal accumulations. I really don't think that it is so sensitive to respond to such a slight change in oil volume, as it seemed to drop less than an 1/8" on the dipstick. Anyways, was running late so didn't have time to figure out what needed tweaking some more, if in fact it was that. I'm also running ROW coding for the cluster since I was trying to see if that would make the oil temperature reading work. You can read all about the oil sensor saga here:
http://forums.tdiclub.com/showthread.php?t=395813
I even got a couple of other sensors to try out. The interesting thing about this ROW coding is that it gave me a reminder to refuel, not just the ding and fuel pump symbol.
So the upper portion of the MFI is capable of Yellow (amber) for the Saudi coding speed exceedance. I also got a yellow oil can when first working on the oil sensor, or if disconnected for a while with the car on. And now RED for some kind of oil system warning.
