Re; valet key cut from existing sidewinder remote key
JELLYBEAN
Central Alberta, Canada
I have two transmitters w/swingblades-question is, can i get
a valet key cut from these? (i do not have valet key)
do the valet keys have a transponder in them? 2000 JETTA TDI
mrGutWrench
Carrboro, NC
'03 Jetta Wagon, 5-speed, 563K Miles (July '23)
JELLYBEAN said:
I have two transmitters w/swingblades-question is, can i get a valet key cut from these? (i do not have valet key)
__. I'm in the middle of all this kinda in reverse (my "new" wagon came with only a valet key). I'm told that the "key cut" is the same but the valet key is thicker and it won't go into the tailgate, etc. So, yes, you can cut off one to the other. Both have the transponder in them and that's a total pain in the @ss! It seems that there's no way to "initialize" the new key without getting raped at the dealer or going to a chip maker (unless you happen to have the "SKC- secret key code").
Rodrigues
Detroit, MI
None
They are both .118-.119" thick however the valet keys side relief (cut on the side of the key) isnt cut all the way other than that they are 100% identical. It's not just the tip its the whole length of the key.
A valet key can be modified by removing a bit of material to open everything.
FLASH13
NORWALK,CA
2002 GOLF
Is There Anybody In Ca That Can Cut And Program A Switchblade For Me? I Only Have A Valet
mrGutWrench
Carrboro, NC
__. Do you already have the switchblade key?
