I was in the believe this was an easy answer to search for, but no
Golf Mk3 Tdi, 1998.
I just change the front wheel bearings and everything around them. And when I started up the car the Radiator fan was running at full speed.
Can the A/C pressure switch force the fan to run at full speed? I did not run the car that long, but the temperature raised a bit, indicating that the temperature sensor was working.
So what can make the fan run at full speed?
Golf Mk3 Tdi, 1998.
