98DIZL
Hello everyone,
I have been a longtime lurker, and only recently registered a few months ago. I have a White 1998 TDI Jetta with dark grey cloth interior that I am looking to sell. It has roughly 160,000 miles on the body and about 115,000 on the engine
I bought the car about five years ago with 58,000 miles on it - around 110,000 miles (three years ago) the timing belt went and I ended up buying a used engine with 55,000 miles on it to have put in. I ran it for a year and then ended up letting it sit for 9 months because it needed some work and I had no cash.
Last January I got it back on the road and it ran fine until August when it started taking forever to start (it would crank for a while before starting). I did the 'unplug the coolant sensor' trick and it worked fine again. After a month or so of that it started stalling out randomly and losing power briefly if I let the RPMs run down to 2200 while down shifting.
It is now at the point where (with a full charge on the battery) it will turn over, sputter for about a full minute (smoking out my neighborhood), never really 'catch' and then stall out.
I have tried my best to figure out the problem, working with others who know more than me, but never figured it out. I've decided to draw the line on the funding and now I am getting rid of it.
What I've replaced / tried in the past few months to figure it out:
I am only asking $1200 or best reasonable offer.
- replaced fuel filter
- replaced starter
- tested glow plugs, had a bad one & replaced it
- tested harness, getting proper amount of power at each finger
- glowplug relay tested out ok
- replaced relay 109
