I hope this isn't a problem to post here. My mk1 1.6L diesel is naturally aspirated, so it's nto a TDI. I also posted this to vwvortex.com.
No fuel is pumping into the injectors, tested by removing the pump to injector line. The pump's stop valve is opening as should be. The belt is driving the fuel pump. I fed fuel by gravity into the line from fuel filter to pump, so I think this eliminates the fuel filter. Is there anything else to check first, on the pump for example, or is it time to replace the fuel pump? Thanks!
