Kentonius
I have a 2002 Jetta Wagon and the parking brake cables were toast. Replaced them with correct parts, etc., according to the DIY.
HOWEVER, now I can't even get the parking brake to engage. Most folks can't get it to DIS-engage, and that is usually a cable problem. These cables are brand new, and when disconnected from the rear calipers, I can pull up on the e-brake handle and it moves the cables.
But, when I re-connect them to the parking brake lever on BOTH rear calipers, I can't even pull up on the e-brake handle. I have adjusted the length with the single 10mm bolt, but the lever on the rear calipers just doesn't want to move.
I'm not sure what is wrong, or what I can do to fix it at this point. Any help is welcome!
